SOLD: 2019 EarthCruiser FX
High Water
Baja Bliss
SOLD
SOLD 2019 EarthCruiser FX
Current Location: Southwestern AZ
Price: $314,000 USD Price reduced to $297,000 USD
Are you ready to go off-grid, be self-contained, and head outside to off-the-beaten-path places? Here is your opportunity to own a 2019 FX (hard-sided) EarthCruiser, 4x4 model with (updated) 30,000 miles. The chassis is a Mitsubishi Fuso FG with a 3.0 liter diesel Fiat motor is used in multiple platforms globally with a great reputation for durability and economy.
This four season adventure vehicle is the perfect size for those wanting more than a van and less than a full-size truck. Sleep comfortably in your own fixed bed and wake up to sunrises in the desert, beach, or other nature spots of your choice. The nimbleness and size of the EarthCruiser allows you to comfortably navigate through cities, small towns, forests, and desert roads with ease.
We originally bought this vehicle for a 2-year journey from Colorado, U.S.A to Ushuaia Argentina, but we were halted after only 6 months of travel in Mexico when the borders closed due to COVID19. Since we are restricted from our original travel plans, we have returned to the U.S. for a reset and have decided to sell our truck named Anahita. You can read and watch more about our adventures with Anahita on our Instagram page @floodexploration or Facebook Flood Exploration.
The condition of the vehicle is excellent. We are obsessed with the care, maintenance, and cleanliness of all our assets and this truck is no exception. It has been kept pet and smoke-free. While we have been off-road, we are careful with our home including the navigator getting out and holding branches away from its skin. Special attention has been applied to with corrosion resistance products everywhere We despise rust and oxidization and have gone to great effort to mitigate those factors of life on the road.
Almost every option was selected when we ordered this adventure vehicle from EarthCruiser. With all the custom upgrades we made, all you have to do is load your own gear and drive away to embrace your adventure. For information on EarthCruiser’s current production visit www.earthcruiser.com
Once you become an owner of an EarthCuiser, you will also have the support of the owner’s group that is invaluable when needing information about places to travel, lifestyle questions, and customization ideas for your EarthCuiser. This is a free owner’s group that can be joined regardless if you by new or used, you are part of a family.
Please reach out to us with questions or to schedule a visit.
INCLUDED STANDARD ITEMS FROM EARTHCRUISER
Heavy Duty tilting Bull Bar
Radiator Protector - Skid Plate
Roof Rack with Scrub Bar
Fuel Capacity of 61 gallons (230 liters
EarthCruiser long travel soft ride suspension system
Radflo nitrogen remote reservoir shocks
Center console in the cab with cup holders & storage compartment & charge ports
Mud guard on stairs
Secondary freshwater tank 22 gallons (83 liters) for a total of 60 gallon (227 liter) capacity
3000 watt Victron inverter
Wabasto dual top hot air and hot water diesel heater
Wabasto diesel cook top
Gear reduction wheel lug nut removal tool
UPGRADE OPTIONS FROM EARTHCRUISER:
CHASSIS UPGRADES
16,500 lb WARN winches, front and rear
Front Torsen Type Differential Locker
Scheel-mann Vario Heated Seats
Powdercoat wheels – satin black
CV Boot Covers (set of 2)
Upgraded lug nuts
Cabin sound insulation
Safe in the center console
LIGHTING AND ELECTRICAL OPTIONS UPGRADES
Solar panels – 3 ADDITIONAL (4 total 150 watts each)
Two 150 Ah Lithium-Ion Batteries
Extra 110v Outlet in the bed area
HOUSE OPTION UPGRADES
Two additional windows in the dinette
Water purification system
Pull out pantry in plumbing cabinet
Bedside cabinet - 3 drawer
Ceiling mounted cabinets above the dinette
Air compressor with a frame-mounted tank, connections on both sides
Mast Steps for cab roof asses
Microwave recess with 120v outlet in the ceiling (No microwave)
POST PURCHASE CUSTOMIZATION
Upgrades for use of globally sourced LSD and HSD diesel fuel and proven to run great
Factor 55 Flat Link XXL with Rope Guard, on front and rear winches
Upgraded rear leaf springs
Additional fuel filtration system installed upstream of the OEM filter. This spin on filter model was chosen for its global availability.
Four mud flaps added with wider, longer, stronger material, and with cable retention.
Two 20 inch light bars on a custom matched powder coated mount
Wired for additional front lighting, harness under the dash
Additional passenger side convex mirror for drivers view front right tire position.
Rear bumper mounted heavy duty powder coated aluminum storage box and gear rack. (Some photos show this during fabrication, however, the final product is powder-coated.) This is a very expensive add on but it provides and excellent and rugged storage.
Suntek clear protection film for all acrylic Dometic Seitz windows
Suntek ceramic UV and heat blocking clear film on the windshield
Suntek ceramic UV and heat blocking 20% shade on side windows
Replaced pass through boot seal with a wider, thicker, higher quality seal
Replaced garage door seal with a wider, thicker, higher quality seal
Air horn on separate toggle/momentary switch. OEM horn is still functional
Converted cab 12v and USB chargers to continuous power, not to ignition switch
CB and UHF radio and Dash Cam on continuous power, not to ignition switch
Reverse audible alarm quick disconnect
Custom privacy/heat/cold screens for the cab
Additional Items available for purchase and not included with the listing price
Rhino-Rack Roof basket
Recovery gear: straps, shackles, etc.
CB and UHF radios
Dashcam with two cameras
*The bicycles, carrier, tools, Waeco cooler, and other personal articles are not included in the sale.
High Water
Baja Bliss
More Interior photos:
High Water
Baja Bliss
Accessories and upgrades
garrettjmu
Spent a few hours chatting with the sellers when we were initially looking into ECs and can vouch for the sellers. A lot of time/thought has gone into their rig and the improvements mentioned. Every thing methodically thought through with intent on each purchase. We ended up pursuing an older EC but this one is a beauty!
High Water
Baja Bliss
Hi Garrett,
Thanks for the kind words. Have you made the purchase yet? if so, welcome to the family. Feel free to give me a call.
spon
This is a very nice truck! I have seen it in person! If I didn't already have an EC, I might be interested! :)
garrettjmu
Hi Garrett,
We are close on finalizing the deal. Just pushing through the last requirements for our financing. Side note for prospective buyers, I've spent 40+ hours researching and talking with different lenders. Happy to chat if you are considering something like this EC (full timer or as a camper).
Steve_382
From what I read, interest payments on the loan can be tax deductible if it's your only second home. Is that correct?
garrettjmu
Somewhat correct... if you are full-timing it (you don't own or rent brick and mortar) you can deduct as well (as your primary).
Two helpful articles below:
DirtWhiskey
Western Dirt Rat
Very cool rig BEST OF LUCK! Would you mind disclosing the lender? Don't need the dirty details. I'm just about to swing on a bigish deal and looking for feedback and experience etc.
garrettjmu
DanoWall
