I truly feel the Columbus Variant is one of the best built tents on the market. However, the one thing it needs is power. AND, now power it has. Sadly, not from the factory, but from a little DIY.
Run power up to the tent using a semi-prototype method. I just grab a cable and plug it into an Anderson Power Pole plug I have in the rear of the jeep. Running it under the lift glass is easy. Later I'll install a drilled permanent passthrough in the body of the tent floor. Probably using the Aqua Signal
For now the manual method works. The 14awg wiring has a full braided loom from end to end. Routing is under the mattress to the front two corners. Along the way, it runs to BlueSea USB ports, and terminates at the beginning of a 16' strip of and RBB LED strip.
The main reason for the power was the lights. The on supplied by Autohome, although adequate, was inconvenient to access....especially if you sleep with your head on the hinge end.
The LED hardware was purchased from SuperBrightleds.com. Wanting either person to be able to operate the lights while lying down, I did not want to use a switch on just one side. This lead to acquiring an RBG remote controller.
I just clipped the connectors off of this one and soldered the wires to the power and LED contacts. Again all of this was hidden under the mattress in the corner of the tent floor full wrapped in braided sleeve.
The best thing about the new LEDs is being able to switch to RED on lowest brightness before turning them off. The memory of last setting stays, and when you need to make a night time Bio-break the low red glow is just enough to see everything but does not hurt your eyes or wake up your wife.
The colors are nice, but I really like the Warm White on medium brightness for general reading. However, if you want, you can go full party mode like my dog did when I was not looking.
From my dog: "The boy just installed these LEDs in my Roof Top Dog house, I mean Autohome. I like the red for when I have to go potty at night. But I have all the party colors for when the pack drops by."
