Wanted: 4x4 RV or Xplorer Type Rig
I’m looking for something along the lines of an Unbound Freedom, Xplorer, or Host 270 4x4 RV. Ideally I’m interested in something less then 30’ long, has a pass through from the cab to the living portion, and is 4x4. I would prefer something with a Cummins but I would look at anything. I’d like to stay under $150k and would be fine traveling anywhere in the US for the right unit. Let me know if you know of anything or have something. Thank you!
Biscuittwister
We are thinking of selling our MB1222 soon, could you be interested in something like this?
No pass thought but,
2015 ram 3500 lone star mega cab with the aisin transmission and 89xxx miles. Here is a list of things about the truck.
Truck has navigation, heated seats, heated steering wheel, electric driver seat, manual passenger seat. Stock suspension and motor other than leveling kit/cold air intake/tuner (I wanted to be able to go to any dealer and grab parts that could/might get damaged/go out). I still drive the truck so the mileage will change. Always serviced on time. Oil change usually done early due to way it is used. Complete list below of things done to truck. It has the heavy duty Aisin transmission.
List of modifications front to rear.
•Midland cab antenna
•wee boost antenna
•road armor stealth bumper
•smitybilt 17.5k winch with wire/Bluetooth remote steel cable
•kc 45inch cured led light bar
•mm3 with 6 tunes to run any diesel fuel even that nasty Mexico high sulfur
•8 switch spod touch screen
•national Luna dual battery controller/monitor
•midland cv radio
•wee boot controller
•tuffy center console lock box
•rear seat platform (seats still under it)
•10 gallon front runner water cell gravity fed under platform
•arb twin air compressor
•national Luna smart solenoid
•Firestone 3 gallon air tank
•auxiliary battery
•bundutecUSA oddesy 205 flatbed camper(more on that below)
•cm aluminum flatbed
•bw gooseneck hitch with hatch on flatbed
•rotopax duo mounts 2 diesel/2water
•air lift air bags in rear
•longhorn 20s with nitto g2s 295/65/20
•rigd tire carrier with matching spare
•new tires less than 100 miles
2017 BUNDUTECUSA FLATBED ODYSSEY CAMPER
•2017 model bought new in 2020
•22 gallon water tank
•led outside lights
•dometic fridge 110L and cooktop
•Lagun table with solid cherry top
•12 inch memory foam queen mattress yes you read that correctly a 12 inch mattress.
•upper shelf storage
•max air fan
•ladder and 3 bar roof rack
•electric roof jacks
•Chinese diesel heater(currently removed for summer just have to mount back and plug in wiring always stays in place)
•his and hers clothing hamper on either side of bed
•pelican 1650 turned into outside storage/cooking area
•alucab 270 awning
•2 bike bike rack on ladder
•c dinette that can turn into a small bed with the table top.
•110 outlets (only with sure power no converter used a goal zero)
•knife magnet
•6 gallon propane hot water heater
•20 pound propane tank
•manual happijacs
•4 anchorguard tie downs
•5 gallon grey tank
•outdoor shower
•Footprint is 81x81 shipping weight is 1400 pounds per title.
For both Id ask 95k. Thank you. Currently located in Memphis, TN.
I’m not wanting a pop up but I appreciate you reaching out.
oskarf150
