Mitsubishi Fuso 4X4 2013 Camper. ***Price drop***
MTAA
Maybe I missed it, but what are the overall dimensions? And there is no camper Air Conditioning , correct? Spare tire is carried where?
No Shower or Toliet?
Thanks!
drudru
Thanks!
22'X7"X10.5'.
No AC.
Back of truck on rack.
Toilet is a portable.
Shower is the entry.
Abitibi
Too bad. I tried contacting you while I was in Mtl but never heard back.
Sent from my SM-G991W using Tapatalk
3 Seats, Sleep 3. 1 double bed, 1 single dinette style bed
Odometer: 52000 km. The engine is a 3.0L Turbo Diesel.
Registered in Canada. Transport Canada National Security Mark (certification). Registered RV in Quebec.
I am seeking 150,000$ USD ****Price drop, now 120,000$***
I love this truck but need to sell. It was built for long term travels for me and my family. But my son is now an adult with very little interest in travelling where the internet is not full strength and I am separated. Time to downsize.
This Fuso has travelled from Halifax to Vancouver, New York to San Diego, Nuevo Laredo to Bacalar.
As a base truck, the Fuso has amazing manoeuvrability. The turn radius is awesome, from Mexico's tight little villages to Walmart parking lots, No problems. The ground clearance is excellent, and it will never overheat, no matter how hard you try. The ventilation in this camper is very effective, the 4 big windows get the wind blowing in no time. You feel outside when all is open, yet the high insulation makes it way cooler than in the sun. And in winter, the Webasto heater keeps it all warm and cozy.
The interior design concept was to keep everything bellow waist, giving a feeling of a wide open space. It is why the entry, which also double as the shower, uses red translucent plexiglass walls, so that it does not cut the view.
With its cheerful colours and warm dark wood accents, it makes for a comfy joyful space. Especially when the sun shines, its lights reflecting on the white surfaces and and brings out the orange and red parts. I will miss that truck.
Truck modifications:
  • Front bumper from Aluminess products inc.
  • Custom hot dip galvanized back bumper/tire carrier mounted with MileMarker SEC15(es) 15000 lbs winch
  • Front/Back suspension full replacement with Parabolic leaf springs
  • ATB Helical Gear Limited Slip Front Differential
  • 180 liters auxiliary diesel tank (adding to the original 125L tank)
  • Webasto Thermo Top C Engine heater.
  • Cab fully re-insulated for heat, vibration and sound using HushMat.
  • Original sound system replaced with 4 speakers and Kenwood DNX891HD 7in Entertainment and Navigation system.
  • Backup camera and self spotting camera (that looks backward to front wheels and axle)
  • Back seat shelvings
  • 5X Super Single 17” wheels with Toyo MT Open Country 35x12.5x17LT tires
  • Viair 450C Constant Duty air compressor with 2.5 Gallons tank.
  • All Manufacturer’s recalls applied up to 2020.
  • Transport Canada National Safety Mark Certification
Camper description.
  • 15’ long, 7’ wide, 6’5’ high. It is made with composite panels layering 1” Gurit CoreCell, 1” 3M Nida-Core and a Kevlar outer liner.
  • 4X Dometic Seitz Windows 900mmX500mm
  • Lewar Low Profile Hatch 577mmX577mm.
  • 4 Outside compartment for component access / storage
Water Systems.
  • 230 liters water tank
  • 3 stages water filtering system (Pre-filter and 2 stage Everpure H-1200 Water Filter)
  • 15 liters/min Jabsco water pump
  • 100 liters grey water tank
  • Webasto Dual Top Evo Water/Air heater
  • Shower
  • Portable toilet
  • All water systems in heated/insulated compartments
Electric systems
  • 4 100 amp/hr Lithium batteries Volthium
  • 3X 160 watts solar panels GoPower (480 watts total, up to 27.5 Amps/hour)
  • 3000 watt industrial pure sine wave inverter for AC power GoPower
  • 50 amps battery charger and MPPT solar charger
  • Inverter Remote on/off GoPower
  • LED lights with white/red mode
Heating systems
  • Webasto Dual Top Evo water/air heater
Other systems/features
  • Engel 80quarts fridge (needs repairs or replacement)
  • True Induction 1800w cooktop.
  • Technivorm Moccamaster KBGT-741 Coffee Maker
  • Breville BREBOV450XL Oven/Toaster
The camper comes with all specialised tools, and a fully equipped kitchen.
Really good looking setup. I was wondering if you know what kind of caveat I should expect for registering this truck in California?
