SOLD: 2019 GMC Canyon Denali 2.8L Duramax 4x4 and 2018 SOLD: EarthCruiser Prototype GZL300 MOD $58k
kslechta
For sale is a 2019 GMC Canyon Denali Duramax 4x4 and 2018 EarthCruiser GZL300 MOD Prototype package.
Full gallery of photos here:
[MEDIA]
Odometer: 60,xxx
$58,000 OBO.
Both vehicle and camper registered/titled in Oregon.
NADA URLs:
($22,460 as OEM)
($34,800 as OEM)
One owner, factory ordered, professionally and tastefully selected modification work done by a number of various off road vehicle shops in WA, OR, or CA.
Vehicle mechanical, warranty, and maintenance has only ever been performed by a Chevrolet or GMC dealership.
This is a turn-key expedition ready vehicle that I’ve been based full time in, more or less, for the past two years, that’s been tested, changed, and overall dialed in through lots of time and effort.
Will provide full systems walkthrough/operation/maintenance procedures, etc.
Fresh 60k mile service, February 2023: Oil, transmission, transfer case, front/rear differential, brake fluid change, fuel/transmission/oil/air/cabin filter change, replaced all 4 OEM brake pads, OEM replace rear rotors, replace left front axle.
__
Avg mpg: City 13-16, Highway 25-28, Interstate 19-22
Length: 22’
Width: 7’ 6”
Height: 8’1"
Truck:
OEM Mechanical Features:
OEM auto locking rear differential, 2-speed transfer case, trailer brake controller, 2” receiver, 4 wheel disc brakes, exhaust brake, variable vane turbo
OEM Electrical Features:
Remote start, engine block heater, collision alert/lane departure warning systems, traction control, Bose premium 7-channel speakers, LTE WiFi hotspot capable, TPMS, power/heated mirrors, 6-way power/heated/ventilated leather seats, power windows/locks, heated steering wheel
Powertrain/Mechanical upgrades:
  • CX Racing external transmission cooler (installed by JR’s Transmissions Auburn, CA)
  • AFE Power Momentum GT CAI w/Pro DRY S Filter and pre-filter
Tires/Wheels:
  • (5) Yokohama Geolandar LT265/70R17 tires (75% remaining life)
  • EVO Corse Dakar 17” wheels
  • Gorilla key wheel lock lugs
Suspension upgrades:
  • Front:
    • Fox DSC 2.5 coilover remote reservoir shocks (valving performed by Accutune Offroad El Cajon, CA)
    • Icon Vehicle Dynamics upper control arms with Delta joints
    • Peak Suspension tie rod reinforcement sleeves
    • PSC sway bar end links
    • IVD front coilover covers
  • Rear:
    • Fox DSC 2.5 piggyback reservoir shocks (valving performed by Accutune Offroad El Cajon, CA)
    • Alcan rear leaf pack: sprung 1300lbs over factory, +1” lift height (installed by Wanderlust Overland Oregon City, OR)
    • WFO limit straps (installed by WFO Concepts Auburn, CA)
    • Custom rear shock mounts (design/fabricated by Richards Performance Muffler Vista, CA)
    • Timbren bump stops (F/R)
    • IVD rear shock shaft boots
Armor and bumpers:
  • 589 Fabrication hidden winch bumper, DOM custom light bar stinger
  • 589 Fabrication front crossmember reinforcing bracket
  • 589 Fabrication skid plates
    • Front
    • Engine
    • Transmission
    • Transfer case
    • Rear shock mount
  • AEV rear differential skid plate
  • Custom .125 wall DOM rear bumper
  • receiver brought in 3”
  • Rocky Road Outfitters Superslider rock sliders
Electrical/Lighting upgrades:
  • Baja Designs OnX6+ 10” light bar
  • BD S4 Sport white ditch lights
  • BD S4 SAE-approved yellow fog lights
  • BD S2 Sport white auxiliary lights - side
  • BD S2 Sport yellow auxiliary lights - rear bumper flush mount
  • REDARC BCDC breaker with bed-mounted Anderson quick connect
  • NAPA AGM battery
Miscellaneous upgrades and features:
  • EarthCruiser kinetic bed mounting system for GZL300
  • Viair 380C onboard air compressor with 3 gallon pancake air tank, (2) quick chucks
  • Prinsu roof rack
  • Matrix mounting pins (machined for holding (2) boards)
  • CBI Offroad Fabrication ditch light brackets
  • GMC all-weather floor liners
  • OEM interior steel trim kit
  • LED bed cargo lamps
  • OEM spray-on bed liner
  • LED reverse lights
  • LED cabin interior lights
  • Roadside emergency kit (flares, fire extinguisher)
  • Stubby AM/FM antenna
  • Center console tray organizer
  • GunVault vehicle cab safe
  • Master combo hidden key vault
  • Cabin waste bin
  • Tinted front windows - 3M film (installed by 503 Motoring Beaverton, OR)
  • Garmin Overlander on RAM Mounts magnetic quick connect
  • Garmin BC35 wireless front camera
  • Rexing v1 dash camera
  • Hi Lift jack bed mount
Camper:
Utilities and components:
  • 180W Sunflare Solar flex PV panel
  • 100aH Battle Born LiFePo battery
  • Victron MPPT 75/15 charge controller
  • Zamp 600W RMS/1200W Peak pure sine wave inverter
  • Redarc BMS1200 BCDC electrical management system
  • 10lb (3 gal) propane tank
  • Propex HS2000 6500BTU furnace
  • Partner Steel 9” 2 burner compact stove
  • Excel tankless hot water heater (to sink and shower)
  • 5 gal fresh water can w/ Aqua King water pump
  • 5 gal grey water
  • National Luna Legacy dual zone 50L fridge/freezer with quick connect base
Interior features and function:
  • 48”x75” memory foam mattress
  • James Baroud awning
  • 8020 folding desk
  • 8020 top-loading cubby
  • 8020 sliding drawer with open base cubby
  • 8020 kitchen counter and cabinet cubby
  • 8020 sink and water can storage
  • 8020 fridge mount
  • Soft-side cabin entry organizer
  • Clothing/coat hook rack
Electrical/lighting upgrades:
  • Garmin BC35 rear camera
  • (3) RIGID Industries flush mount LED scene light
  • (2) Reading lamps
  • (3) Overhead LED light strips
  • (4) LED exterior running lights
  • BD dome switch (yellow) outdoor entry step light
  • BD dome switch (red) utility closet light
  • BD dome switch (white) battery cabinet light
  • (2) BD dome switch (white) garage cabinet lights
  • West Marine Kona 12V fan with custom swivel mount
Miscellaneous features and components:
  • (4) Blue Ridge Overland zippered utility pouches
  • 12V direct (3) 45W USB-C and (3) USB-A
  • (5) 120VAC outlets
  • Spare tire carrier/aluminum outdoor kitchen table
  • Retractable camper step
  • External hose spigot
  • NOCO weatherproof 120VAC shore power connect
  • Indoor/outdoor hot water shower with folding indoor catch basin
  • Waste management station
  • Paper towel rack
  • Built-in drain plug
  • Upswing entry door
  • Closed-cell foam floor mats
  • Heavy-duty window zippers
  • Tool garage with plywood mounting panel and lids
  • 2 gallon diesel Rotopax and wall mount
Equipment included with vehicle:
  • Tool kit
  • Wheel lug key
  • Air compressor hose/regulator
  • Road flares
  • (2) Fire extinguishers
  • Covercraft sun shield with storage bag
  • Dune flag
  • Dune flag mount
  • Camper jack stand set with (2) crank keys
Extras included:
  • 2 sets of keys (ignition/entry fob)
  • 3 sets of camper keys (cabin/compartment)
  • 2 GunVault safe keys
  • 1 receiver pin key
  • Tailgate
  • Spare and replacement LED lighting
  • AFE air filter cleaner
  • Touch-up paint
  • Door seal material
  • Camper step and tire carrier spare parts
kslechta
Rig's going to storage while I'm away on some international travels. It is possible to coordinate remotely while I'm away - find me on other socials with the same username.
HarryBB
Is that an after market aux fuel tank in the spare tire location? If so who makes that and where did you mount spare? On edit - never mind where you mounted spare I see it in the pics.
project13support
