SOLD - FOR SALE: 2011 AT Chaser Trailer
Rube2K6
2011 Adventure Trailers - Chaser
  • White powder coat with black fenders
  • Steel powder coated nose box
  • Independent trailing arm suspension with air struts
  • Six-foot cargo box provides 46 cubic feet of storage
  • Cargo box has gas strut assisted lift cylinders
  • Locking tail gate- 16" x 32"
  • Rubber matting on bottom and sides in cargo box
  • Cargo tie downs inside cargo box
  • Drop leg tongue jack
  • 2" rear accessory receiver
  • 2” Multi-axis coupler
  • Electric brake axle
  • Wayne's RV Stabilizer
  • Thule Rack load bars on adjustable track
  • Eezi-Awn Series 3, 1800 rooftop tent
  • Eezi-Awn 2.0 awning
  • 3 Eezi-Awn Series 2000 Rec-Vee panels and floor (pic not mine, copied from the web)
  • Two 5 gallon fuel cans with AT holders
  • 19 gallon water tank with hand pump
  • Utility shelf - shaped and finished hardwood plywood
  • LED Rectangular Floodlight- rear of trailer
  • Interior LED nightlights with dimmer switch
  • Odyssey AGM group 31 battery with aluminum hold-down bracket
  • NOCO Genius 10 amp onboard battery charger with shore plug
  • Sun Guard solar controller
  • Plug-in connector for solar panel
  • Volt meter
  • Auxiliary 12v outlet on tongue box
  • 12v outlets inside cargo box
  • Locking tailgate option
  • 5 lb. propane tank with aluminum mounting bracket
  • 35” BF Goodrich KM2 Mud Terrain tires
  • 5 on 4 1/2 Jeep TJ wheels
  • Canvas trailer cover
  • No trail rash. Has never been on its side or top.
  • Second owner. I purchased it in January 2014. Just don’t use it often enough.
  • Located in Fallbrook, CA
  • More pics available if needed
RKRUGER
Adventurer- Toyota Nut
As a new Chaser owner, I will say I am blown away by the build quality on these trailers. I guess you could call me a Fanboy. This one has all the goodies. I think it’s a steal. GLWS.
Rube2K6
No, my plan is to sell my TJ and the trailer, and replace them with the larger JK, then just camp out of that. No need for a trailer any more.
LRNAD90
"The trailer box is HD 14 gauge, powder coated steel, which is assembled from 7 total parts.."
Base Weight looks like it is 700 lbs, not sure of weight as outfitted..
"Dry Trailer Weight: 700 lbs.
GVWR: 2,700 lbs.
Payload: 2,000 lbs."
xander69
