Newbie Here.....Gettin' ready to pull the trigger on a Expedition 3.0......or even a well-maintained Used Expedition 2.0 (if I can find one)
However....Two questions for the general group (in no particular order):
And....I realize that the Expedition 3.0 is a new product, so if your answers apply to a Expedition 2.0 that's okay.
I can infer.
1. Have you ever considered (or had the need for) some form of a water filtration system?
1a. Does OGT even offer something like that as either "Stock" or an Add-on?
I've pored all over their website & if water filtration is mentioned, I can't find it.
.....All it takes is ONE bout of Montezuma's revenge to start thinking about filtration.....don't ask me how I know
2. How many days have you been able to run completely "Off Grid" - using only the "stock" Electrical System ?
2a. Did you feel the need to upgrade from the "stock" ?
Guesstimated/Projected MAXIMUM "load" would be:
* The fridge - 24hrs/day
* Two Laptops - 2-6 hrs per day each - Max
* Two Phones - 2-6 hrs per day each - Max
* Two Tablets - 2-6 hrs per day each - Max
* One string of LED lights - 2-6 hrs per day - Max
* One hour (or so) of interior lights (reading,etc.) per day
This is a bit of an older post, but it looks like no one gave you any answers...
Water filtration -
I just use a regular inline filter that attaches directly to the hose. You can pick them up at any camper shop, and many regular hardware stores.
That being said, we don't actually drink the water from the tank. All of our drinking water gets run through a
Lifesaver jerrycan. One of the best investments I've ever made!
Power -
The most I was really able to manage fully "off grid" from the stock electrical system was about 2 days. That is if there is no charging available at all.
The stock system leaves a lot be to desired so yes, I did feel the need to upgrade to:
- (2) 100Ah BattleBorn LiFePO4 batteries - these have more than double the usable capacity of the stock batteries.
- Redarc BCDC1212 charger - this runs directly off of the 7-pin connector (no additional wiring necessary) and keeps the batteries charged up during long driving days. If you will be driving multiple days in a row, especially in hot weather, it's vital to be able to charge while driving.
- Victron 100/30 solar controller fed by 280 watts of panels - in full sun this will top up the previous nights usage before noon.
Laptops are your big battery killers. We would generally wait to charge those until the batteries were full and the charge controller was "floating", i.e. all the power from the panels just goes straight to the laptop, with no draw from your batteries.
Bear in mind that your fridge doesn't actually run 24\7. Temp is going to have a pretty major effect on power usage, but it is never running all the time (and they are shockingly efficient).
With this setup, charging at least one laptop every day, and sometimes 2, and being somewhat diligent about usage otherwise, we can pull 4 days without any inputs - probably 5 if I knew for sure I could get a full charge at the end of that day.
If the sun is shining, the only limit is water.
