Stewart & Stevenson 4x4 Expedition Truck, $75,000
1997 Stewart & Stevenson LMTV. $80,000
Priced for a quick sale!
  • Chassis: AT005655ECFF
  • 32k Miles
  • 6.6-Liter Turbodiesel Inline-6
  • Allison Seven-Speed Speed Automatic Transmission
  • All-Wheel Drive
  • Gray & Black Paint
  • LED Lighting
  • Gray Cloth Upholstery
  • Dinette w/Sleeping Surface
  • Galley w/Refrigerator & Induction Cooktop
  • Workstation
  • Wet Bath w/Shower & Composting Toilet
  • Diesel-Fueled Air Heater
  • Senville Mini-Split Air Conditioner
  • 20" Steel Wheels
  • Solar Panels
  • Lithium Battery System
  • Freshwater & Gray Water Tanks
This 1997 Stewart & Stevenson M1078 is a former military vehicle that was purchased by the seller approximately four years ago and subsequently converted to an overland-style vehicle with the addition of a camper cabin. The truck is finished in gray and black, and power is with a 6.6-liter turbodiesel inline-six mated to an Allison seven-speed automatic transmission and an all-wheel-drive system. The camper is outfitted with a galley, a dinette that converts to a bed, a workstation, and a wet bath. A retractable awning is positioned on the camp side, and other equipment includes LED lighting, reverse- and side-view cameras, a diesel-fueled air heater, a Senville mini-split air conditioner, and a Dometic refrigerator and freezer. Power equipment includes a 1820watt solar panel array, a 400ah Lion Energy lithium battery system, charge controllers, and a 3,000-watt inverter. Work under current ownership is said to have involved replacing the engine, tires, pinion seals, drive shaft u-joints, alternator, and voltage regulator, revising the differential gearing, rebuilding hydraulic cylinders, and changing the oil, coolant, and rear differential fluids. This M1078 camper is now offered in Tennessee with installed component manuals and a clean Arizona title in the seller’s name that lists the truck as a 1997 Stewart & Stevenson Military.
The M1078 is a 2.5-ton Light Medium Tactical Vehicle (LMTV) that is built on a chassis derived from the Austrian Steyr 12M18 truck. This example has been fitted with a camper cabin and refinished in gray and black, with bedliner material applied to the cab. Equipment includes LED lighting, locking front door handles, and a receiver hitch with a seven-pin connector. An 1,880-watt solar panel array with pneumatically operated slide-out panels is mounted on the camper roof, and other features include an entry ladder, a CVT manually operated canopy with two support poles, sliding windows, and utility connections for power and water.
Black 20″ steel wheels wear with 395/85 Goodyear MV/T tires that are said to have been installed under current ownership along with balancing beads. A spare is located on a power-operated boom behind the cab, and stopping power is provided by air–assisted brakes. Work under current ownership reportedly included overhauling the hydraulic pump for the spare tire lift and replacing the rear sway bar bushings. The central tire inflation system works well.
The bolstered high-back seats and center jump seat are trimmed in gray cloth. Features include a side- and reverse-view camera display, metal window cranks, a center tray, a master power cutoff switch, and textured floor mats.
The two-spoke steering wheel fronts an 80-mph speedometer, push-button transmission controls, and auxiliary gauges for fuel level, oil pressure, coolant temperature, voltage, and front- and rear-brake air pressure. The six-digit odometer shows 32k miles, approximately 25k of which were added under current ownership.
The living quarters have a 75″ ceiling height and are outfitted with woodgrain flooring, white walls with mountain graphics, and overhead lighting as well as storage cabinets, insulation in the walls and ceiling, and blackout curtains. The dinette has bench seating upholstered in gray cloth in addition to a wood table that can be lowered to form a sleeping surface. An adjacent workstation has a desktop, USB power ports, and open shelving. Climate control equipment consists of a Senville mini-split air conditioner, a diesel-fueled air heater, and two Maxxair power-operated ceiling vents.
The galley is located at the front of the cabin and features woodgrain countertops, a double-basin sink, a Duxtop two-burner induction cooktop, 120-volt electrical outlets, and a Dometic dual-zone refrigerator and freezer. The wet bath has a sink, a composting toilet, a tethered shower sprayer, and an overhead exhaust vent with an integrated light. House power equipment includes a 420-Ah lithium battery system, charge controllers, and a 3,000-watt inverter, 20amp shore power battery charger, a Bosch 4-gallon electric water heater, 122-gallons of freshwater, and a 30-gallon gray water tank (the water system has heated lines and tanks.
Additional work included replacing the alternator, voltage regulator, fan solenoid, and an oil line as well as changing the oil and coolant. The engine is equipped with a solar trickle charger and a hydronic block heater.
Power is delivered to all four wheels through an Allison seven-speed automatic transmission and a single-speed transfer case. Work under current ownership reportedly involved modifying the differentials with 3.07:1 gearing, replacing the pinion seals and drive shaft u-joints, and balancing the drive shafts.
Owner’s manuals for installed components will accompany the truck.
Watch the Video Tour
I have plenty more pictures, video upon request!
Truck located in Chattanooga Tennessee
Just dropped the price to $75,000, hope that helps if the new owner wants to make some upgrades or personalizations to the truck.
If you’re interested let’s talk! 2244005580
Thanks,
Jon
More details on my rig!! Fully ready to go in the greatest adventure.
wfuller42
Great looking rig and I enjoyed the walk-thru video. I'm in the Southeast and looking for the first overlanding rig for a yearlong full-time trip with my wife and dog. We're experienced backcountry campers and prioritize off-road, off-grid capabilities. Also want to make the most of ski season.
I noticed your outdoor tanks. Our ideal setup could handle Rocky Mountain winters. How does this do in the cold?
That sounds like the perfect adventure.
The truck does very well in the cold!
All water lines and tanks have heat strips or pads on them so they don’t freeze.
Also, I have the hydronic engine heater so you can make sure in those very cold days the truck always starts warm protecting the engine!
What other questions do you have?
