Root Moose
I've started thinking about how to lay out the rear storage in the XJ. As a result I'm creating a list of stuff to take as spares and tools for the Jeep itself.
I'd like to make this list as small as possible but be enough gear to deal with issues if they occur.
The list below is kinda nuts - too much stuff. Unfortunately I've been in situations where I could have used this stuff - but thankfully not all at once.
Chalk it up to the joys of wheeling a 15 year salt belt truck.
Most of the bulky stuff may end up somewhere in the tent trailer.
Here's the list so far; what would you add/remove?
- misc hand tools (SAE and metric - AMC couldn't pick one, damn)
- FSM on netbook/iPhone/carputer/whatever
- hard copy of Lubrication/Maintenance section of FSM (fluids, amounts, etc.)
- u-joint press
- EFI tools
- OBD-II scanner (hand held separate from carputer setup)
- alternator
- starter
- coil rail
- spark plugs
- wheel bearings
- u-joints
- 2 or 3 spare fuel injectors
- serpentine belt
- spare oil pan plug(s) (don't laugh - lost one for ~6hours once when flooded engine required fluid change - had to spend extra overnight by the time we found it)
- brake lines (the rubber part
- filters (gas, oil and air)
- oil for diffs (1 change each diff)
- oil for engine (1 change)
- oil for trans and t-case (1 change)
- bearing grease
- brake fluid
- JB weld
- anti-seize
- penetrating oil
- dielectric grease
- fuses
- rudimentary electric repair tools (crimp, test light, multimeter)
- arc welding rods
- "shop towels"
- "kitty litter"
- spare fluids container
- catch pan for fluids
- hazard markers
- tarp/rope
- coveralls
- eye protection
- gloves (mechanic and nitrile)
- hand cleaner and "wet wipes"
What parts of the XJ fuel injection system fail "hard" with no warning? We've been been lucky so far but are due for some parts to go.
Axle shafts were intentionally left out . With locking hubs and a full float rear a broken shaft can be worked around.
That's got to be at least 200 lbs of stuff.
Thankfully most of the parts (used) are already inhabiting my workshop.
What's the best way to store rubber stuff like the belts and hosts so that UV doesn't break it down as fast?
Recovery gear, emergency food stuffs, first aid, etc. was intentionally left out to focus on the vehicle spares.
Is this overkill for touring North America?
- u-joint press
- EFI tools
- alternator
- starter
- coil rail
- spark plugs
- wheel bearings
- u-joints
- serpentine belt
- bearing grease
- brake fluid
- JB weld
- anti-seize
- penetrating oil
- dielectric grease
- fuses
- arc welding rods
- "shop towels"
- "kitty litter"
- hazard markers
- tarp/rope
- coveralls
- eye protection
