Random Moon Shots
pyro4fun
This is on Lake Tapps WA. Mt. Rainier in the background on the 4th of july, Im a pyrotecnition and this was the view before and during the show :)
phxtoad
Moon shots
Shot back on '02 with a Canon P&S - Scottsdale, AZ at DC Ranch. Apparently the moon is a hexagon. Who knew?
Same evening a bit later. Funny, it looks round here...
phxtoad
Since we are on the topic (so to speak). This is an oldy, but a goody. Moderator's: Kill it if you need to... I completely understand. :)
suntinez
The moon has proved quite elusive for my camera skills, I'm still trying to get it right. But this one came out nice, on a one hour exposure - with the north star doing its thing, and the waterfall all lit up. There WAS a moon, but it didn't make it into the picture!
Every Miles A Memory
Suntinez that is an awesome shot!
Were you using a digital body or shooting film?
I've always wanted to try shots like this, but none of my digital bodies have good results for real long exposure work.
Anything over 10 minutes and the shot is too grainy! I'm really jealous!
DrMoab
Not sure about Canon but I know my nikon has a setting where on any exposure over a min (I think its a min) it will take an equilly long exposure of nothing...just black and then it somehow melds the two images together to reduce the noise. It seems to work quite well.
suntinez
It was a Nikon D90. A friend of mine had done the same shot from her patio using her Canon so I tried it too. I still don't know what I'm doing, just playing around and got lucky! One day I'll get the moon :sombrero:
DrMoab
I was under the impression that the longest shutter time on the D90 was 30 sec.
Donn
i'm sure it has a bulb function. 30 sec is probably as long as it will go before you have to manually set it open and time it yourself.
That's great that a Nikon D90 will produce a shot this crisp.
I'll have to try it with my Canon to see. Maybe i'll set up the shot and try it with both the 5D and the wifes 30D and compare, but I'm thinking it'll be so grainy I wont be able to post anything
Thanks for the info
LilKJ
Camping outside of Durango....
I cheated a little and put a headlamp in each tent:coffeedrink:
78Bronco
It was a journey but not by land
On a flight from Vancouver to Amsterdam
attachment.php
Photog
Here is a link to long exposures for the Canon 5D & some 30D info.
http://photo.net/canon-eos-digital-camera-forum/00QWU0
With long exposures, the sensor is on and charged for the full exposure time (of course). This heats up the sensor, and causes many of the photosites to react to the heat of the neighboring photosites. This reaction is recorded as a color, in the processor. This is digital noise. The sensor tends to react predictably, and will create almost the same noise, in the very next frame.
With that knowledge, the camera companies created a noise reduction process called, Dark Slide (a term from back in the film days I believe). Here is how it works.
1) You make a long exposure (say 30 seconds).
2) When the exposure is complete, the camera leaves the mirror down, and fires up the sensor for another 30 seconds, to finish the total exposure process.
3) The processor takes all of the color noise that showed up on the 2nd frame (dark slide), and subtracts it from your original exposure. This removes most of the color noise from your image.
Good or bad, that is how it works. I know the cameras use this process in the 15 second to 2 minute range. I don't know if they do that for a 1 hour (or longer) exposure. Batteries might be dead before that could all finish up.
Also: The Dark Slide setting can be turned on/off in all the cameras I have seen, that offer this function.
Ancientsojourners
