Air pressure in lieu of water pump?
Jeff Wanamog
Off Road Camper Guy
Has anyone ever used the air pressure from an onboard air compressor in lieu of a water pump? It would be like killing two birds with two stones!
Shouldn't be too hard to set up.
Thanks.
Jeff
Jeep
Supporting Sponsor: Overland Explorer Expedition V
You would have to use a pressure tank with a diaphram to prevent aeration.
PhulesAU
you would just have a giant paint sprayer.....I don't remember which of the popular shower systems is a heatable garden srayer. Replace the pump with a screw in plug , with a ??Shrader?? valve to pressureize the tank.
Grim Reaper
you don't the diaphragm.
This is not uncommon in vintage campers. My 59 Airstream is set up this way.You can fill it with a compressor. Only need about 40 PSI. My 59 can even be pressurized with a bicycle pump with the Schrader that is on the fill neck. Does need to be a pressure vessel. Old beer keg would be the easiest starting point.
PhulesAU
Good God man:Wow1: A beer keg!!!!:drool: I hope Ya'll have better luck finding a "old" one in usable shape. That would be a great start.
xcmountain80
I Made a jerry can with a double tapped cap one for pickup and the other for air filling, but the can exploded before I could test it. I used a onboard compressor and a metal jerry can. I know I know, a more substantial tank would be ideal but you might be able to pull it off.
A
chris_the_wrench
Fixer & Builder of Things
This is the way old VW's windshield sprayers worked. The water bladders had a schrader valve on them. Some of the systems were even plumbed into the spare tire, which was not too great. You would have clean windows but eventually a flat tire especially since the systems were prone to leaks.
-Chris
rusty_tlc
Not only Air Stream used this method, it was common on Travel Trailers through the 70's.
IdaSHO
IDACAMPER
Yep, all sorts of RVs used to use such a setup. Most pressurized the tank using a small hand pump near the sink.
jesusgatos
Hah, what a trip! I was just thinking about this (using air-pressure to move fluids). Would be cool to use air-pressure to move waste-water (to cut down on wasted water) and if your water tanks could hold the pressure, it would make a good backup in case the electric water pumps went out for whatever reason. Hmmm...
ntsqd
Heretic Car Camper
For a small tank, like found on an M416/M101 or similar, a pressurized tank could work well. For a large tank it can still work, but the tank itself will need to be a lot more robust than if a pump were used.
rusty_tlc
One advantage air pressure systems have over electric is that they are quieter. However flow drops off over time.
I think you could build a small air tank and pressure switch/solenoid in the system that would maintain a constant pressure.
A $40 Pep Boys electric pump could be used to fill the air tank and act as an OBA source for tires, air mattresses, toys etc.
Rando
I considered this as well when installing a water tank in my wildernest. I came to the conclusion that while it would definitely work, the extra weight and cost of a pressurizable water tank and plumbing and a regulator, far outweighed the cost of a RV water tank (~$40) and an electric water pump (~$30). Even with already having 5 gallon pressure vessels on hand (Corny Kegs) it seemed fairly inefficient as unless you happen to have a round hole, a cylindrical tank stores about 30% less water than a square tank.
On the other hand if you have a CO2 tank for filling tires, you could have carbonated water with this system! Add some flavour syrups and you have a mobile soda fountain.
jesusgatos
I was thinking something more along the lines of a system that would have a separate pressure-tank that would only pressurize the lines, so that the holding tank wouldn't have to be pressurized.
PNWav
