kcOtma (Tacoma?)
I have gone through the same process you are going through now.
I have a lovely "little" 95 Toyota Xtra cab that has seen most of Utah, two trips to Cabo and who knows how many shuttle runs transporting my whitewater raft. While it has been a great little truck, thats its problem. I needed something bigger to transport all the coolers, frames, gear and people for rafting, plus I help chase and tow for my co-workers off road racing
http://fireguysracing.webs.com/ and the 3slow was just not intended for that kind of use.
- I wanted a diesel since with a moderate load the mpg does not get killed
- 4x4 with a solid front axle
- Preferred an xtra cab but crew would be OK
- Short bed to help with turning radius
I know you can build anything to suit your needs but I was looking for something that had most of these attributes as OEM. Both to keep down on expense, and I knew I would be modifying enough things on what ever I ended up with, so engine swaps and axle transplants was just too much $$.
Loved the Cummins of the Dodge, short bed, xtra cab, perfect. Just could not find anything in my price range that was not trashed. In my price range was the:
- 95-97 F250 Xtra Cab/LB or F250 CC/SB,
the Twin Traction Beam (TTB, gotcha 'ntsqd') with leaf springs is just a punishing ride.
- 95-97 F350 only came as either a standard cab long bed or CC/LB and I wanted the interior space.
I wanted a shorter wheel base to help with turning radius but having driven it for a couple of weeks it is really not that bad. Having said that, it is not my daily driver (Subaru wagon) and most days I walk to work.
As for Ford, this is the first I have owned. We have 3 as brush trucks (7.3/7.3/6/0) and 3 as ambulances (7.3 truck body/6.0 truck body /7.3 van body) on my fire department. As fleet vehicles I have no complaints with them, we have had leaks, fault codes and other problems. We do all our own scheduled maintenance so I kind of know my way around them. The problems we have had are those inherent in all mechanical machines.
Every brand and model will have problems, I have owned VW, Nissan, Audi, BMW, Land Rover, Chevy, Toyota and now this Ford. I was the Parts Manager at a Land Rover dealership and wrote service at another one for seven years. I reiterate
Every brand and model will have problems, base your decision on that vehicles condition, records, and history.
