It was midday. The sun was particularely fierce today and we had little shade. Returning to the RN1 was not really an option for us. We checked out the area and driving around it was no option either.
We started by digging into the ground underneath the construction. It was well thought out as the base was a metal plate. We cleared the plate of all ground... another 5mm won  :roll:
The tyres were let down to 0,5 bar but we were still too high. We opened the rooftoptent and removed the mattres, pillows, ... .
The front cleared now, but the back of the car was still too high. We let out all of the remaining air out of tyres (0bar)... still no go  :?
So I climbed on the roof and Josephine took the wheel. We counted to three and I jumped on the roof while Josephine moved forward for a few centimeter at a time. And counted to 3 again, etc... It scraped a bit, but it worked.
Once we passed we got the compressor out to inflate the tyres again. I really did not want to damage the tyres here!
First tyre, Ok, switches the hose to the second tyre and then *poof* the compressor died.   :tantrum:
These kind of things really eat at you. Patience is virtue, but when you are trying to move forward so desperately you really don't want a compressor to die!
Checked the fuse, checked cabling, checked overheat protection. Everything look allright?? This is the moment were you kick a tree (it hurts) out of frustration. We had three flat tyres and we only had two spares. We needed that compressor!
So in the midday heat I started to dismantle the compressor. The compressor was bolted on the roof, so I had to work on the roof... no shade there..
