If you can't afford a winch.
007
Horrible reviews on that contraption of junk, why would you reccomend such a thing?
Eventhough
These are an option, just like using a Hi-Lift to winch with the appropriate straps. The BIG downside is you are right in the middle of everything if something happens to go wrong/break.
Ray Hyland
Come-alongs can be very useful.
I sometimes carry one if I am going up some tricky trails on my own and if I have lots of space in the back of the truck.
I have a 12000 pd hydraulic winch as my main recovery tool, but I have a high-lift if I get a log or rock wedged under the axle, or if I need to lift the truck up and out of a deep rut. Less damage than dragging the truck off with the winch alone.
The come-along is very useful for tricky sideways situations, or for positioning logs etc if you are in a situation where getting the normal winch into play is difficult. Also if you need to winch yourself backwards off of something. I know you can do all of that with the hi-lift as well, but I find the come-along a lot more convenient to use in those situations than the hi-lift.
But the amount of time I actually use and need it is rare, so it only comes along when I have the space and weight available, or if I will be on a tricky trail.
Most of the time I just use it to pull firewood from a slash-pile or clearcut.
Cheers
Ray
mogwildRW1
For real work, the manual kind, like tipping your rig back over, you'll want to trust something like the TIRFOR, or GREIFZUG
They run a special cable, but grip that cable like no other, and the pull gobs of weight safely.
Ray Hyland
Trev, the Tirfor is an amazing tool, but the last time I looked at them they cost nearly the same price as an electric winch.
So a very cool, very capable, but fairly expensive (to me) tool. At least the ones I looked at, I may have been looking in a very expensive place.
Sirocco
TIRFOR is the only recommended hand winch. They can be had for cheap on ebay (here in the UK) just make sure you get the cable with it as it has a tapered end. normal cable will not work.
Used one once to haul a fully loaded 90 around a corner and up a very steep slope. It took 2 of us, but it was very handy indeed.
G
Nonimouse
Cynical old bastard
"Used one once to haul a fully loaded 90 around a corner and up a very steep slope. It took 2 of us, but it was very handy indeed."
And very entertaining to watch it was to!
LR Max
Local Oaf
If you can't afford a winch, then a) don't get stuck or b) don't travel alone + tow strap.
There, easy fix.
mogwildRW1
They go pretty cheap on the used market, watch Kijiji and those kind of sites. Just make sure the cables in good shape, they cost an arm and a let.
I know its probably near the same price an an entry level winch, but when your winch is dead, or your ride is tipped sideways, its a real life saver.
I agree with LR Max, don't wheel alone if you can't afford good recovery equipment. :)
Sirocco
Forgot about that.
We used it to haul it up Dunlop Hill in West Wales. Around a switchback and on some.
G
Nonimouse
Cynical old bastard
I can top trump you there, we used one to hall a 110 (not mine) up Pheasant Pen Steps - all the blessed way
abctrash
