Moody said:I have an issue with the HVAC system. It will only blow on settings 3 and 4. Everything else works fine. I was told by a friend it was the resistor under the glovebox. Can anyone with more smarts than I comment and confirm before I tear apart the car?
ckkone said:Hi Roger,
I used The Google:
http://townhall-talk.edmunds.com/direct/view/.f1234ee
Supposedly you need to replace a Fan Control Amplifier
From my looking around, if you have the fancy digital setup,(like the QX4 Infiniti) it is the digital control, and if you have the basic knobs, it is the resistor. Let's hope it is the latter.Grim Reaper said:Ewwwww that is not going to be cheap if it is a digital control instead of a simple resistor pack.
Moody said:From my looking around, if you have the fancy digital setup,(like the QX4 Infiniti) it is the digital control, and if you have the basic knobs, it is the resistor. Let's hope it is the latter.
Strange thing is, it works in setting 3/4 and I can still turn it off....
Thanks guys.
