02 Sensors
hrjaw
At what point would you change your sensors? my 99 Grand Cherokee has all four original sensors on it and I am at 150,000 miles. is this a "maintenance" item that should be changed or wait until they STB? Jeep is running fine, gas mileage has not changed, etc.
Roger
As long as they are functioning the way that they are intended, there is no reason to replace them. Just wait untill they throw a code.
Only an issue if mileage drops, or if you have an inspection issue with the ODBII scan. If it's not broken don't mess with it.....
I prefer to replace them between 70,000 and 100,000 miles. With time they degrade. Deposits tend to skew the readings. Fuel mileage and performance will improve with new sensors.
Some vehicles list the O2 sensors replacement in the maintenance schedule as 100,000 miles. I think by that time you have waited too long.
I replaced mine at 72k miles and did see the fuel mileage return to "normal" I gained 1-2 mpg in city driving. That is almost a 10% increase for my truck. Well worth the cost.
Don't buy universal or cheap sensors. Go with OEM quality. Performance and life are better.
another good point. thank you.
Most OBDII systems are adaptive, which means they will shift signals to the engine slightly as signals from sensors shift slightly, in order to compensate for small changes.
As the O2 sensors wear out they change signal. The OBDII will accommodate this change to a degree, but will eventually be unable to do so.
The manufacturer of the sensors will tell you they are good for around 50,000 miles. That's not to say they won't work beyond that point, but by that point they are probably starting to drift the signal. Unless you have the tools to read the signal in real time, you don't really know.
As with a lot of items, the O2 sensors are a maintenance item. Change them on a predetermined schedule. Sure they cost more than a case of beer, but so what. Gas these days is not cheap either, and your gas consumption is directly tied to the 02 sensors and how well they work. Since you are already at 150,000 miles, I would consider the O2's DOA and change them whether they are working or not. By the time they throw a code, they are long gone. Buy the best you can afford, and change them now.
sebsync
