03 Tacoma Elocked rear axle
taco chaser
Supporting Sponsor
I have a 2003 Tacoma rear axle with low miles for sale: under 12,000 miles
Yukon 4.88's
Solid spacer and shim pack replacement
Timken bearings
Pinion adapter flange for the 4.88 ratio
Stock axles, brakes, and ABS sensors still intact
Trail gear diff armor
Dash switch included if wanted
E locker harness can be pulled if necesary
Everything works great, you will need to replace the break hard lines on the housing, I had to use the T and the threaded toyota ends of the brake lines.
PM me or post if intrested and we will exchange phone#'s then.
I'm asking $1000 OBO
My name is Matt and I'm located in Northern California.
Goldenbora
