07 + Fj Cruiser Winch Bumper
GorillaTec
On Sale for $500 bare metal or $600 with powder coat.
Details
GorillaTec LowPro bumpers are built tough. Using 1/4 inch steel construction throughout the bumper, bumper frame, and recovery points, strength and durability are one of the key features among many. An additional 10 gauge front shroud is added for increased durability.
Features:
* Low Profile 3/4 inch shackles
* Through welded shackles for strength and durability
* Drain ports
* Accepts a variety of winches up to 12,000 lbs.
* Internal gussets for extra rigidity
* AC line clearance (required for earlier models)
* Innovative design allows for increased airflow to radiator and to assist in drainage.
* Precision cut using the latest laser and waterjet process.
* Uses a standard 10 inch x 4.5 inch winch bolt pattern
* Designed and Manufactured in the U.S.A
* Powdercoat and LineX Available
-The LowPro bumper is easily bolted to your vehicle using the existing mounting bolts and 2 additional bolts (provided by GorillaTec).
-Some winches require relocating the solenoid. For solenoid relocation mounts please contact us
Specs
-Brandon
bdpkauai
