07 FJC &Trailer for sale $26k
afj4x4
It's time for someone else to enjoy the adventure.
I am doing what I never thought I would, but it's time to let go.
Located - SE louisiana, Franklinton
Defects - cracked lense on one roof light, all four batteries work but should be replaced.
2007 FJ Cruiser-VOODOO BLUE 4x4 Automatic Transmission, Remote keyless entry system, Cruise control , Power outside mirrors with illuminated markers, Rear privacy glass, Rear wiper, Daytime Running Lights and Back-up Sonar, full size spare (exterior rear door mount), Active Traction Control, Locking rear differential, 115V, 400-watt power outlet, Exterior color-keyed door trim inserts, Multi-information display floating ball type (inclinometer, compass, temperature), Leather-wrapped steering wheel with integrated audio controls, Roof rack, All weather mats and cargo mat, towing hitch, Arm Rest.
My additions
Toyota VIP RS3200+ Security System w/Proximity Sensor, 5-BFGoodrich 315/75R16 KM2 mounted on 16" Pro Comp Rock Crawler (87-6883t) 16x8-3 3/4 backset (under 3000 miles on tires), hypertech speedometer calibrator, body mount chop, regeared Nitro 4.56, Marlin inchworm lefty 4.7:1, 2.5" Sway-A-Way Coilovers (101-5600-8) attached to Camburg Performance 1.25″ Uniball Upper Arms with Toytec 1" front differential drop, Old Man Emu Heavy duty Rear lift coil springs [896] soften by 2" Sway-A-Way Shocks , Demello Off-Road Front Bumper no hoops with a set of Acro lights, Skid plate, Warn Winch M8000 with 80' of 3/8" Amsteel Blue, Baja Rack's roof top tent rack with 4 Fuego Lights by Soltek mounted on a drop down rack, All-Pro Sliders, Extreme Links with Skids, Magnaflow muffler and high clearance tail pipe, GMC map light Mod, Sound deadener on roof, Back-up and rock lights, A-trac/locker hack (Cut free), Traction Control Cancel, Dual battery setup using a 1315-200 Surepower Battery Separator controling two AGM Batteries,Mean Green 200 amp Alternator w/AGM charge modification, aux fuse panel, Tekonsha proportional trailer brake controller, flush mounted 7pin trailer jack, Motorola HF850 Bluetooth Car Kit, Garmin nüvi 1450 w/North America NT 2026.10 Maps, Clarion DXZ665MP-Sirius (PAC SWI-X Steering Wheel Radio Control Interface) with Aux-jack, AM/FM, in-dash CD-MP3/WMA playback capability and nine speakers including sub-woofer,13" FM Antenna, Icom IC-706MKIIG Transceiver and Cobra 19 CB Mirror mounted with PA, OEM Light switches for roof top (inboard and outboard) driving and rock lights, 2008 side mounted sunvistors,2nd (high-pitched) horn, 3-12volt outlets (two in front console and one in rear cargo space).
Trailer
Built by AspenTrails Xpedition (Bob Brown - skersfan on fjcruiserforums.com).
Full heavy tube frame with steel fenders and three compartment box, tongue battery box, line-x and paint to match FJ, coupled with a Lock N Roll Articulating Trailer Hitch, Dexter torsion axle with brakes, Dual battery charger, batteries, 125 watt BP Solar panel, ProStar-15 Controller, fuel jug rack for 5 - 5 gallon square jugs, 20 gallon fresh water tank w/pump, Roof top tent, Camping labs awning, Olympian grill, propane tree and miscellaneous hoses, ARB 50gt freezer/fridge pull-out ( l am keeping the fridge to reduce the price), All-Pro swing out spare tire mount,3-BFGoodrich 315/75R16 KM2 mounted on 16" Pro Comp Rock Crawler (87-6883t) 16x8-3 3/4 backset (same as truck)
The FJ Cruiser and trailer allowed us to get away and enjoy time away from the masses when we lived in the desert of southern California. We have reached a place in our lives where we are now living our dream in Louisiana away from the masses and no longer need a vehicle to carry us away. Set up for over landing or boon docking you too could be carried away. All systems were well maintained and fully operational 227,600 miles on the odometer of which only the last 2k were in Louisiana, the drivers seat and head rest show the worst wear and tear, I am the original owner. The FJ even comes with Toyota's famous fj inter-fender well cracks (it's only cosmetic and hasn't changed since late 2007).
$26K will secure the rig for you. The pictures should allow you to see the current condition and are located at www.afj4x4.com. Any questions can be sent to randy@afj4x4.com. The domain name can be included in the sale.
