08 and up switch panel.
silvrzuki77
explorer
Hey guys, I hope this can help someone out there for mounting their switches. I came across a site RV-project.com and used a company called front panel express to build a blank fill panel for the upper coin tray area on the newer Vans. (Disclaimer I have no relations with front panel express) I downloaded the software and grabbed my micrometer and started measuring my ARB switches and my air gauge and designed a new plate. Front panel express took my info and CNC a plate out of aluminum anodized black. Total cost $35. Anyways here is the results.
Temporary installed
The red gauge is a different brand switch than ARB so it sits different. Will replace it soon and get some fill covers till I use the empty spots. If any one wants my template I can email it to you and you can move things around or what not. Hope this helps.
Chris
screwball48
I have often wondered when someone would make a switch plate for that area. Kudos to you. Gives you an option other than the factory upfitter switches there.
Mcoleman
