12v amperage/power load for off-road lights.
Pskhaat
2005 Expedition Trophy Champion
I'm looking at putting some more/different off-road lights in. Starting on the wiring.
Looks like some of the highest-wattage off-hwy lights are ~100 watts. Is that about standard? Hopefully I can afford some HID-style and reduce the amperage.
If @~100VA that means each of them draw nominally a little more than 8 amps @12VDC, right? I am investigating a relay bank so want to make sure I can handle the proper load.
Mike S
Sponsor - AutoHomeUSA
You should calculate the wire run for the total rated amperage X 1.5, and go one size larger. relays are available to handle up to about 30 amps. Fuse the wire at 1.5X the actual max amperage load.
BiG BoB
It's not the "correct" method, but here's what I do...
Pretend that the vehicle runs on 10v ;)
10 is an easier number to divide by, and in this case 100W is 10A
It also gives you a nice safety margin :)
Sean
Pskhaat
My current concern is that the relay rack I'm looking at only has 20A@24VDC relays. I would assume that these relays are VA (watt) rated? Thus, 480VA right; at 12v that is 40A rated?
Stepping up to the 30A@24VDC rack gets quite spendy for some reason...
crawler#976
Scott,
The 35W HID's from Checker Auto are about $250.00 for a pair including tax, and worth every dime. They draw less amperage than one 100W KC Daylighter or similar light, and are a lot brighter.
Mark
Mike S
You need only concern yourself about the load on each switched circuit. If you design the circuits so that only one pair of 100W lights is on each one, then you will have a load of 2 X 8.333 Amps (or 16.666 Amps total) on that circuit.
Amps X Volts = Watts. 20A x 24V = 480W, 480/12 = 40 Amps. Make sure that they switch at 12V.
M
ntsqd
Heretic Car Camper
I don't know what relays you're looking at, but 30-50 amps in a Bosch pattern (typical automotive) relay is fairly inexpensive. I just ordered 10 of them at about $8 each.
Pskhaat
It's a switched remote-control relay bank with relays on the PCB (non-pluggable :( ); not specifically the relays themselves that are of price.
Palli
