12v fan for tent?
V30CREWCAB
anyone use a 12v fan of some sort in your tent at night. would like some circulation while camping in july and wondering what solutions you've come up with. looked at the walmart clipon auto fan, but wanted to see if there was any better solutions.
pugslyyy
Computer case fans are all generally 12V, quite efficient, and are very, very inexpensive. In fact, you or a friend probably has a couple that aren't being used.
I have a tiny one in my fridge for circulation (better/more even cooling), 4 behind the fridge (thermostat controlled, driving air over the absorption coils), and one big one over the stove venting to the outside.
vati kaki
I use a clip-on auto fan
16
Hilldweller
SE Expedition Society
we have several
One of them is designed to sit in a cup-holder and plug into the cig lighter. Works okay.
One is a clip-on and draws too much juice.
The best is one that plugs into a usb that I found at BJs or Costco. Low draw, decent breeze.
We've got a battery powered unit and a Fantastic Fan too. The battery thing is bulky and kills batteries fast. The Fantastic is fantastic but only when there's shore power. It really uses amperage.
Roger M.
I use the 12V portable Fantastic Fan in my CVT, with a Yeti 400.
You can't leave it running constantly, and you have to keep it on the lowest setting when it is running, but I get lots of run-time with it.
But even on the lowest setting, it remains the best camping fan on the market. It blows all the warm, damp air out of the tent in just a couple of minutes.
If camping in really hot weather, I bring one of the inexpensive 12V battery packs designed to boost your car battery in addition to the Yeti, and I run the Fantastic Fan off the booster.
If it's not really hot, and I'm just getting the tent cooled down for 15 minutes before hitting the sack, my solar panel keeps the Yeti up to charge, and the fan doesn't impact Yeti capacity noticeably.
Yarjammer
Wellreadneck
We use a Coleman tent fan with the LED lights. It works great and puts out the perfect amount of light for my RTT. It uses four D cell batteries and they usually last long enough for a couple multi day trips of use in the evenings (maybe 24hrs total use per set of batteries).
mmaattppoo
I too run Coleman LED light / fans. I soldered in 12v DC to 6v DC stepdown transformers in lieu of D-cell batteries and run them off my aux battery. These are perfect for those hot summer nights when you need a breeze.
The fans are mounted to the hoops using Ram mounts.
Beowulf
mmaattppo,
I'd love to see more details on how you did the 12 to 6 conversion install.
mmaattppoo
mmaattppo,
Fortunately it's relatively straight forward but there are a lot of steps. Here's a brief rundown of the main steps and materials you will need:
The main component that makes this work is a 12V DC to 6V DC stepdown transformer (see image below). These are readily available on eBay and Aliexpress for $10 or less plus shipping.
The transformer has a labelled +/- 12V input (from your vehicle's electrical system / aux battery) and +/- 6V output.
You need two conductor insulated wire (SOOW cable is what I used; see image below) to run 12V power to the transformer input. This type of cable is readily available at Home Depot and Lowe's and is sold by the foot. This cable has four main benefits:
1) the wire it contains it's stranded and is available at a sufficient gauge to easily handle the low amperage 12V input for the transformer.
2) the cable is quite flexible and easy to cut, strip the insulation, and is tough as nails.
3) the diameter of the cable is perfect for threading through a nylon strain relief gland so you don't accidentally yank the wire out when you flail about in your tent while dreaming of your next project (see image below for strain relief gland)
4) it's not overly expensive...always a good thing.
I soldered a 12V cigarette lighter style plug to the supply side of the 12V power cord and use a corresponding flush mount socket (wired to my aux battery) as the power source.
The 6V output side of the transformer solders to the +/- tabs inside the body of the fan effectively replacing the four 1.5V D-cell batteries that would normally be wired in series to produce 6V.
If you're wondering about fusing for this setup, there is a 5 amp fuse in the cigarette plug (just less that the 6 amp limit of the transformer an comfortably less than the max amperage the fan/LED will ever pull...even when operated simultaneously. Additionally, I run power to my tent through a 12V breaker panel and weather proof Amphenol military circular style connector.
To mount the fans I used the following Ram Mounts parts:
1) Base Plate with round base.
2) a 2" plastic extension arm.
3) a mounting clamp that fits the 7/8" (?) diameter tubing of the tent roof support hoops.
The base plate attaches to the fan with self tapping screws, or small wood screws.
I think that about covers it. Let me know if you need more details.
Enjoy!
jesus m anderson
