kittenfactory
1983 Ford E350 Shuttle bus with a 460 engine and c6 transmission both rebuilt less than 20,000 miles ago. A gear venders overdrive was also added at the same time. The 4x4 conversion was done by Advanced 4x4 in Salt Lake. Inside is a bare bones rv setup with a queen sized bed in the back and a twin sized bed on the side that converts to seating. It has a 26 ish gallon water tank with sink and sprayer that will fit out the window for desert showers. A propane/ electric fridge is also part of the camper setup. It has working a/c in the front and rear converted to 134a. Two captains chairs that swivel in the front. Both gas tanks work. 6 matching tires and a spare underneath. Also has a 2nd battery under the hood for auxiliary use and a battery isolator. I'm sure there is more I could add but you simply have to check it out in person. Will edit post with more photos as soon as I can upload them to my computer. Asking 4000 obo. Feel free to give me a call about it (eight one four) 227 8421. Thanks Alex.
