1983 Toyota Sunrader - $12,500
eporter
Basic interior build. The exterior has been redone. Seems like a good price for what these have been going for lately.
Model: 210RBK
74,800 Miles
22r 4 cyl-4 speed replaced with newer 5 speed manual 16-19mpg
New Clutch
New Brakes and Master Cylinder
Back bearings replaced
4 Newer Yokohama back tires
2 Newer Ranger front tires
185R14
Tune-up done
Weber carb with K&N Air Filter
New rear bushings
True 1 Ton Rear Axle
Exterior vent holes, accesses and front windows removed. Fiberglassed, primed, painted and clear coated at marine shop. No leaks. No insect or rodent entry holes.
Custom rear bumper with 2" receiver.
Basket on that has been removed but can be added back if you will use it.
Ladder for roof access with swing arm bike rack for 2 mounted on it.
Black 4.5 gallon pvc water tube with hose spigot mounted on back bumper. Can be set on roof for solar showers or just carry extra water.
ARB 8x8 Touring Awning #814410: has been removed to other vehicle. Will give $350 allowance to purchase new and help install if wanted. Brackets are already in place. Very simple.
RV Systems hard wired back-up camera with 7" screen.
Tinted windows on all glass
All windows open with screens
500W Renogy Solar Panels mounted on roof.
Renogy Rover 40amp MMPT Charge Controller
4 V-Max 6V AGM 235 Ah each-total available 470 Ah wired in series and parallel for 12V mounted in 2 custom diamond plate boxes in floor.
V-Max 175Ah house battery under hood with battery isolater wired to LED light strips in house.
Power Tech-On PS 1003 Pure Sine Inverter 2000W continuous 4000W Peak.
Intel Power Charge Wizard Converter PD9260C
1000W output 13.6VDC 60Amp
1-60' 1-16' 10 gage power cords for shore power with 30/50Amp adapters.
2 New Fan-tastic fans 3 speed with covers.
ROCA from SVB Folding Teak table top with removable Lagun mount.
Removed old flooring replaced with 1/4" closed cell foam then Marine grade 1/4" plywood. Finished with peel and stick wood grain waterproof vinyl flooring slats.
Removed/replaced cab floor insulation and carpet with new.
Ruvati Stainless Bar Sink 7.5x16 drains to portable 5 gallon gray water jug.
5 gallon water jug gravity feed to sink.
Thetford Porti Potti Curve slides out under sink.
Mr Heater Portable Buddy
1-5 gallon propane tank with 10' special Mr Buddy hose. No inline filter required.
Room for additional tank.
CO2 Sensor
I used 1Burner High Performance Butane/Propane stove.
Toaster Oven
750W Microwave
32" Vizio Smart TV w/Chromecast-mounted with full swivel arm.
Sony Blu-Ray Player for movie night.
4 - 6' Lodge Poles installed to hang 4 hammocks.
Use 2 for lounging/sleeping and 2 for overhead storage.
3" Foam for bed
Very well insulated: 1/4" closed cell foam 3M77 against fiberglass then 1" rigid then 1/4" closed cell foam stapled on framing-1.5" total insulation. Very cool in summer, very warm in winter and quite from outside noise.
6 custom storage benches with hidden locked security box.
I removed ARB 50 qt. Fridge/Freezer that always ran great just from solar power.
No smoking, pets or funny smells. Very clean. Actually smells a bit like cedar from custom benches.
Drove from Seattle to Key West and back with no issues. Would do again with no worries.
Family medical issues forces sale.
Serious inquires only please. Thank you!
$12,500 obo
jgwarren319
