Hello,
I have for sale a 1988 Land Rover 110 2.5TD.
Mileage:82,007 miles
Price:$44,000 USD
The color is Trident Green with white ribbed roof. Has sunroof but no air conditioning.Grey cloth seats, 5spd. transmission.Imprted from Verona, Italy in April where it spent its entire life. The body work is in excellent shape. The paint is mostly original with the exception of the hood,front end and passenger fender. The spare wheel had been kept on the hood but now is mounted on wheel carrier on rear of vehicle.
The interior is very clean.There is a small hole in the vinyl covering of the rear seats but apart from this they are in as new condition.The windshield has a few very slight scratches but remainder of glass is blemish free.Floor mats front and rear are relatively new. Headliner and door cards are in nice shape. There are two slight cracks on dashboard but otherwise it is in great shape.
The chassis is corrosion free. The common problem areas with bulkhead,frame,outriggers and rear cross member do not exist with this 110.I have not undercoated or repaired anything underneath. I want interested individuals to see exactly what they are getting.
Current mileage is 82,007miles on vehicle but only 7,000 miles on a no expense spared engine rebuild. The work was performed by a very well respected shop in Verona in 2011.
Key items renewed are as follows:
Piston kit. Block bored +0.50 over
Bearings/connecting rod
Intake/exhaust valves/guides
Oil pump
Timing belt/tensioner
New injection pump and injectors
New water pump
New turbo
New motor mounts
New radiator
New rotors/pads/brake lines/brake shoes/wheel cylinders/calipers
Rear main seal
New clutch kit
All fluids and belts
I have all receipts. The cost was$10,750
Since April I have changed all fluids and filters. New battery.One shot lubricant in swivel ball housing.Front mud flaps.Rear brake light assemblies.New brake master cylinder.New turn signal switch.Hazard switch.5 new 235/85/16 Cooper AT3 tires.
I have all import documents in order.It is registered/licensed/insured in Colorado. I even had it emissions tested.
Starts easily when cold. Cruises at 65-70mph on highway. Very fuel efficient. Suspension is compliant.Brakes work well.
This is a wonderful,trouble free 110. It has been a great weekend get away vehicle and will be a joy to own.
I have a lot of photos on Defender source as well.
Thank you for taking the time to read my ad.
Price:$44,000 USD
Oil pump
New water pump
New turbo
New motor mounts
New radiator
Rear main seal
New clutch kit
