1991 RRC Hunter Built Parts Truck
abrooks
RRC Hunter Trail Parts Truck
1991 RRC Hunter Edition trail truck. 1/405 for 1991. Well loved and well built, but I've used her for what I needed her for. She should be be considered an Excellent parts truck or a project.
The important parts:
Hunter solid (non-sunroof) roof
Non-ABS Brake System
New, just installed Terrafirma HD lift with 0 miles
Terrafirma trailing arms
Genuine Rear rubber floor mats
RTE radius arms
New Calipers with 0 miles
Extended brake lines (uninstalled)
Extended poly bump stops
D2 upper front shock tower rubber rings
+1" rear spring spacers
Equipe front diff guard
Heim jointed Panhard rod
Rockstar Fab Sliders
New Cap/rotor/plugs/wires/vacuum lines
Newly boiled and pressure tested radiator
New Fuel Pump installed
New Fuel Filter
New Power Steering pump
New Viscous Fan
Intact heated windshield
It can be delivered on a set of twist alloys with tires to get it onto a trailer. Currently not running due to the rad being removed. I did drive it into the driveway but likely needs at least heads to be road-going. In terms of rust, it's better than most. Sills are ok, rear wheel wells are similarly OK. Rear Crossmember is bad, as are lift and tailgate. Bulkhead is good, floors seem fine.
This is a great opportunity to get some of the neat Hunter parts onto your SWB and get a turn key lift and some solid armor out of it.
Asking price is $2250. This will not include the seats. If desired, I can give you the leather seats out of the LWB including genuine waterproof covers, or if you really must have them, they can be negotiated separately including Tactical seat covers (they won't be cheap). Stock front and rear bumpers can be included if you'd like.
Located in Arlington, VA. Not willing to separate more than is specified above. Will need a trailer and winch to move. Happy to answer any questions. image7.jpgimage2.jpgimage1.jpg
abrooks
$2100. Can also discuss the v-belt 4.6 that's almost done being rebuilt that was destined for it as a separate purchase.
Goldenbora
