vladi80
Can't belive I'm doing this but here it is. 93 clean title 3xlocked with 156k miles up for sale in nor cal. Zero rust with ome 2.5 inch lift heavies all around along with slee black three degrees caster correction bushings installed by Gary at Mudrack. ARB front with warn m8 winch with factor 55 and synthetic rope. Warn hid driving light and rigid d2 fog pods. Up top no name flea bay light bar and rigid like pods "plenty bright" wheels are scs f5 in matte bronze and 315 be Goodrich ko2's with less than 3k miles. Front and rear drive shafts have been serviced with new joints all around. Rides smooth as glass no vibes no wobble. Metaltech powder coated sliders. Up top there is a home made rack with Diamond racks 2.0 clamps and unistrut to support the maggiolina topline hard shell tent. Under the hood dual AGM battery setup with blue sea ACR and 2000 watt AC power in the back fed from the auxiliary battery. 150amp sequoia aletrnator with photoman's braket and pulley. Inside the cab besides the magic dial there is a double din Kenwood deck with navigation and upgraded speakers. There is also a sirius satellite radio with lifetime subscription an outdoor temperature display, voltmeter and coolant temperature koso display. Interior has been sound dedned including the doors. As of maintenance the front axle service was done at 120k along with new plugs distributor and valve cover gasket . Tstat, water pump ,blue fan clutch and new koyo radiator done at 140k. Front and rear differentials, transfer case and transmission fluids flushed and replace at 120k and140k with royal purple and Mobil 1 transmission fluid. PHH/FHH done as well with new EGR valve along with throttle cable. New brake pads all around with new rear rotors. Interior is in good condition with no rips or tears. OK enough with the good stuff. Here's the bad stuff, clear coat is faded on the hood and roof driver side mirror got a little shake. Other than that it drives even better than it looks. Passed smog with flying colors last month. Expo price 16k.
