speedpin
1994 RHD Arles Blue Defender 110 HCPU less common than typical defenders. 96k original miles. Factory fitted 300 TDI diesel engine, 5 speed manual. Original paint in great shape. Has some blemishes from age/use. No rust/corrosion issues. It looks like it had a camper in the bed as it has no dents or wear from use.
Been in rover enthusiasts hand since import.
Only selling as I have moved to a 2022 defender that I am building for off road use.
More videos and pics https://photos.app.goo.gl/CiqB28ummEVkiEV17
-Nicely tunned injection pump which makes an appreciable difference in power. Can cruise on highway at 70mph without any problem.
-Allisport full size intercooler
-The instrument binnacle is metal Raptor version and another binnacle on the center dash holds the boost gauge, 12 volt sources usb/micro and volt meter.
-EGT gauge installed
-Lots of maintenance, most with paperwork (2023 big service, paperwork pic in link)
-New radiator, fan, fan clutch, shroud and cooling system/hoses/clamps etc (replacing an electric fan setup that was retrofitted)
-Silicone engine hose kit and piping
-All new front timing case, gasket, crank seal, timing belt, tensioner, pulleys, oil cooler thermostat, oil lines, oil pressure switch, etc.
-Valve cover gaskets, breather hoses, pinion seals front and rear, etc
-New Clutch, Throw out Bearing, slave cylinder
-Updated rear main seal while the gearbox was out
-Complete service including all fluids, valves adjusted, filters and fuel pump timing.
-Front and rear driveshafts rebuilt
-Disc brakes from and rear
-ARB rear diff cover
-Full 2 inch hitch receiver with frame tie ins and trailer wiring hookup
-All the springs and shocks are new Terrafirma commercial duty. About 1” lift, Rides great.
-Battery box and chassis, body is free of rust. Previous owners have steam cleaned and had been re protected over the years.
-New radius arm bushings and various steering bushes, properly shimmed swivels/alignment
-1.4 Transfer case with PTO output for winch
-Serviced and fully functional factory option Fairey PTO winch with new Synthetic line (much safer)
-Galvi PTO winch bumper with end caps
-HD steering links and tie rod ends
-Fitted bed mat.
-Folding side steps
-OEM Spare tire bed mount
-New genuine LR gearbox cover.
-Full LED light package to include the headlights
-Everything functions as it should, heater, lights, horn, wipers, squirters, etc
-Deep dish alloys with 5 like new 235/85 16 Yokohama Geolander M/Ts
-All glass is good
-FULL complete and clean interior to include cab headliner and pillar trim. Also have middle seat and seatbelt if you want to swap out the console.
This Rover drives straight down the road very comfortably, back roads or highway. Needs nothing! I have had MANY classic Defenders and this by far is the nicest and best taken care of truck I have had.
Clear Virginia title in my name.
