BMWJNKY
I'm selling my factory locked 1994 Land Cruiser. All 3 lockers are working fine and I try to activate them anytime on dirt so they keep working. Lifted with J springs in the front and heavies in the back and OME shocks. I painted the truck with bedliner in June. Regular maintenance is done and logged in a spreadsheet (oil changed and tires rotated 12/27). Yakima roof bars and wind deflector will be included. I custom built a rear sleeping platform with slide out drawer on HD ball bearing sliders. I replaced the front and rear brake pads and rotors at the end of summer, bypassed the LSPV and flushed the brake fluid as well. Working factory alarm with new remote and new master key from the dealer. I replaced the heater valve and related hoses at the end of summer. Front crank seal and oil pump cover are dry. Radiator and starter were replaced just before I got it in the summer of 2015. New front brake calipers, front brake hoses, hood struts and distributor shaft o-ring on 1/13/17.
I also have a box of spare parts, 2 oil filters, 2 oil drain plug gaskets, 1 fuel filter, front wheel bearings, radiator hoses, about 3 feet of gold stripe heater hose, breather hose, brand new set of parking brake shoes, used but good condition front & rear brake pads and I'll throw in any other spare pieces I come across that are related to the vehicle.
Upgrades:
CDL switch and pin 7 upgrade, this allows the lockers to be used in 4H and 4L
Snorkel
Extended diff breather hoses
Tinted windows
OME J springs in the front & OME heavy in the rear with OME shocks
285/75/16 MT tires are less than a year old and in good shape with a full size spare
New AGM battery
Trail Gear front bumper
22" LED light bar and PIAA fog lamps
Front sway bar quick disconnect kit and front sway bar drop spacers
Pioneer 6.5" 2 way speakers in all 4 doors
Phillips HIR gen 2 headlight bulbs
Cree LED reverse bulbs
LED interior lights & license plate lights
Outside temp display
AVS window vents
Custom sleeping platform with locking drawer on HD ball bearing slides
It has 270K miles, it has been a great vehicle and taken my family and friends on some fun adventures but it's time for it to go to a new home.
$8300 obo, $7800 without the sleeping platform, I'd also take another $120 off if you didn't want the roof bars and LED light bar
*CLEAN TITLE IN HAND*, tags are good till July 2017, message with any questions, full album of Pics- https://goo.gl/photos/QFViuDi4er4HABmE8
Upgrades:
Snorkel
Tinted windows
New AGM battery
AVS window vents
