1994 M1079 full build out done right Brutus Adventure Driven
sethro80
1994 M1079 Stewart and Stevenson, made in the USA military truck. $143,500.00 OBO 32245 miles, driven weekly so milage will go up.
This is a head turner, friend making go anywhere adventure camper, very capable off road. 47 inch tall tires. Just performed a full detailed service. Vehicle 12’ 2” and weighs 22,500 pounds Registered as a C class RV, no CDL required. We have owned this incredible camper for 7 years, have gone through all systems extensively, mechanically sound, fly in and drive anywhere you like. If bought local I will be more than happy to maintain this truck after the sale. Tons of new parts, I have all records that I can send you. Spares and extra parts and info come with the truck. Truck is a full time 4x4, has a Turbo Diesel Caterpillar 3116 Mechanical engine mated to an Allison 7 speed automatic transmission.
Gets 7.5 MPG Cruises 65 MPH as it high speed gears, max speed is 74. Has fully functioning CTIS tire inflation system with upgraded controller you can customize tire pressure 24V electric cab lift pump installed, runs cab and spare tire hydraulics Added a 12V air grid heater to engine, to aid in cold weather starts Insulation wrap added to intercooler, exhaust and air intake tubes, helps performance and deadens sound Exhaust brake added with floor foot switch Functional either cold weather start system on a switch Custom one off cab/roof rack with sealed Alu-Box’s as storage 24V COME-UP winch with one off camp painted Bubba Rope and Factor 55 winch thimble for recovery of vehicles that try to follow Brutus. Enough KC lights to be seen from space forward facing, automatic KC reverse lights wired in, roof rack side lights mounted above windows wired to switch, interior ceiling LEDs wired to door switch and dash switch, choice of red or white. Bluetooth stereo, Apple Car Play, cab stereo four speakers with two 10” subs on a Kenwood amp Fabric pouches added to hold misc items in cab Heated scheel-mann seats from Germany Upgraded power/heater mirrors Boost and Pyrometer gauges added to cab. Reverse camera Fully insulated cab, nice and quiet Full AC install, nice and cold Custom one off ICON 3.0 CDC valve shocks build specifically for our truck. 56 Gallons of fuel in main tank with a 10 gallon reserve Custom Trailer hitch added 5 outside belly storage box’s added Rear solar motion light added to light steps at night Small shovel added to from of cab CAMPER: Truck will run indefinitely on 1300 watts of solar, 4000 watt inverter and 600 amp hours of Battle Born lithium batteries. System is wired 24V with a 24V-12V transformer to a single 12V battery to power 12V electronics. 11 batteries total on truck. Solar system also charges the 4 chassis batteries on truck, no need to plug to shore power to keep batteries fully charged. A shore power battery charger is also wired up to keep all 11 batteries fully charged if needed. Hot water shower in the corner of camper, 8 gallon ISOTHERM hydronic/110v water heater Outside shower Goose Gear cabinetry through out 110V Insta Hot water heater at kitchen sink Acuva UV drinking water treatment at kitchen sink XL K-9 Aluminum table mounted on a slide between cab and camper Single handle residential faucet at kitchen sink Trash A Too added to hold trash above engine air cleaner Wrap On toilet mounted in drawer, made in Japan, no black tank Exhaust fan flush mounted to rear door. All LED lighting inside camper with external security lights on a switch Induction dual burner cooktop, outside 11V plug added to cook outside if desired ARB dual piston air pump hidden under table area for airing up anything, external hose connector mounted by air tanks Eberspacher D10w hydronic heater max 32,400 BTU on boost mode, heats: water, air and engine coolant, 2 fan air mover under kitchen table on a thermostat Diesel air heater as a supplement heater, redundancy Fully functional black out shades in camper, removable fabric curtains also included 3 electric camper mounted Dometic awnings Queen size bed on electric linear actuators above dinette National Luna fridge freezer from South Africa on HD slide, the largest one they make Camper Bluetooth stereo with subwoofer Flip down TV Starlink internet Tons of interior storage 78 gallon of fresh water on a pump located under dinette seats USB charging station to recharge electronics Will drive anywhere in US to deliver to buyer, or can help with shipping.
Located in Belgrade MT
8e0e967a-42ca-41fa-8d99-589741267d6c_1_105_c-jpeg.851947
WOW! 30 lights on the front should give plenty of illumination.
Interesting build. glws.
M meadow build
