1995 Land Rover Discovery-SOLD
ColoDisco
Golden Colorado
For sale is my 1995 Land Rover Discovery, purchased February 2009.
Mileage: 207,291
Color: Alpine White
Engine: 3.9 litre V8
Transmission: automatic
Suspension: Terra Firma big bore expedition 2" lift
Tires: BF Goodrich mud terrain KM2
Full time all wheel drive with 4wd and center differential lock
Added equipment:
Steering guard
Trail gear sliders, welded to the frame
Terra Firma steering damper
Extended stainless steel brake lines
Modified brownchurch roof rack for roof top tent, with fabricated feet for awning mount. Hi lift brackets made to fit the 60" hi lift.
Custom front bumper with 2 hella 550's, winch mount drilled for a warn winch.
Stainless steel limb risers
Extra fuse block for roof rack accessories
Dog guard in rear, used as a gear stowage
Power inverter mounted to rear of center console
LED cargo strip light connected to door switch
Rear cargo area stripped and sprayed with bedliner
12v outlet added to rear cargo area
I am a Land Rover tech and have taken very good care of this vehicle. When I bought this truck it was in need of a lot of care. I started out building it for off-road and ended up focusing on building it into a overland truck. The value in this truck is with all the services and modifications added. I have driven this truck all over Colorado and Utah and it has performed flawlessly.
Services performed:
Engine fully resealed including the rear main
Reconditioned heads
Crower Cam and lifters
Kick down cable replaced with a heat sleeve added to protect it from the exhaust
All 3 differentials serviced twice.
Coolant flushed
Power steering fluid flushed
New high pressure power steering line
New power steering supply line
Oil still new, changed in April
New air filter
Viscous fan clutch replaced
New plugs and wires
Replaced exhaust down pipe gaskets
New serpentine belt
New fuel pump and filter
Defender front brake upgrade with vented rotors
New rear brake rotors and pads
Transmission fluid flushed with new filter
Transfer case resealed
All 4 tie rod ends replaced
Rear driveshaft u-joint conversion
Front driveshaft from Bills englewood driveshaft
Resoldered rear window control module
Known issues:
-Front sunroof rails failing, don't open the front sunroof and it will be fine.
-Possible coolant leak at drivers side of radiator. There is some dried coolant but it holds pressure. May just be spillage from having the engine out for reseal.
-Drivers door latch sticks. Most likely needs a adjustment but may also need a new door latch.
Ram Xmount on dash not part of sale. Need it for my iPad. Maxtraxx mounting pins on roof rack not included. Last couple of pictures are how I used to have it setup. Just add your own awning and roof top tent and continue the adventure!
Asking $5500 obo
Contact me through email and I will pass along my phone number.
bpeterson35@icloud.com
Goldenbora
