1997 12 valve with Grandby Flatbed 4wheel Camper
Helicase
Accountant errors= collect camper in your favor. In hot water with the IRS so liquidating assets.
Located in Boise, Idaho.
88,000.00 OBO, I lose money on this build that was just completed one year ago and used 5x.
1997 dodge 12 valve cummins 8foot flatbed. All mechanical diesel with 80,000 miles on original engine with manual transmission. Not A SINGLE sensor or CPU required to operate.
Major upgrades:
ARP custom age 625+ head studs
toyo M55 commercial off road tires <1000 miles
bilstein 5100 shocks all around
dynatrac locking hub retrofit with WARN hubs and CAD delete. major reliability upgrade
RCV racing CV front axle shafts 35spline nickel plated. no binding in 4wd tight turns and huge strength upgrade
Two ergonomic front seats from scheel-man germany
Eaton true-trac helical gear based limited slip differentials front and rear, all the pros of lockers with no cons or fail points
high end bluetooth stereo with compact sub and balanced 3 ways Hertz speakersx4
2022 grandby full size flatbed camper. See attached specs. Upgraded with 2000 watt inverter, triple lithium dakota batteries and two roof mounted solar plus two plug in overland solar flex panels. Weeks of off grid. Added roof mounted mobile HD business class starlink dish.
  • FWC Koontz, Thadeus Grandby FD 11-17-2021.pdf
Price Drops coming every week or 2 until gone. 80K today.
here is a pic from this weekend on continental divide. will climb a goat track with eaton true-tracs. RCV 35 splines allowed climbing with full turn and zero binding. I know there are some of you here that can appreciate this. I was able to work zoom with court case while elk hunting from montana idaho border.
Weatherman
