1998 Land Rover Discovery LSE 4.6
ColoDisco
For sale is my 1998 Land Rover Discovery LSE, purchased October 2013.
Located in Golden, CO
This is the 50th anniversary of Land Rover edition.
Mileage: 175,765
Color: White gold pearl metallic
Engine: 4.6 litre out of a Discovery II with pinned cylinder liners
Transmission: Automatic
Suspension: Terra Firma big bore expedition 2" lift
Tires: Goodyear wrangler duratrac
Full time all wheel drive with 4wd and center differential lock
Dual battery system with separate fuse block for accessories
2 12v outlets added to rear cargo area
Extended stainless steel brake lines
I am a Land Rover tech and have taken very good care of this vehicle. It started out with the factory supplied 4.0 which the previous owner blew up. I took the opportunity to upgrade the engine. It is a known failure of the discovery II 4.6 engine that the cylinder liners can knock, and the engine I received was known to have this problem so I mitigated this with the pinning procedure. I have driven this vehicle all over Colorado, Moab Utah, Grand Canyon Arizona and Grand staircase Utah without any incident. The acceleration is amazing compared to a regular 4.0. Litre. This is not meant to be a grocery getter, it is built for adventure and if you know Land Rover it does not disappoint. I performed all the work to make it reliable for overlanding or as a solid off-road rig. The real value is in the services performed, suspension and tires.
Services performed:
Installed 4.6l engine with pinned cylinder liners
Engine fully resealed, this includes the rear main
New oil pump
New water pump
New thermostat
Reconditioned heads
Front and rear diff fluids replaced with redline shockproof.
Center diff has fresh 80w
Coolant flushed
Power steering fluid flushed
New power steering supply hose
Oil changed 2k miles ago
Lower radiator hose replaced
New air filter
Viscous fan clutch replaced
New spark plugs and wires
New serpentine belt
New fuel pump
New fuel filter
Replaced the windshield last summer
Repacked all 4 sets of wheel bearings in March
New motor mounts
Resoldered rear window control module
Known issues:
-Cylinder liner pins seep oil. Very minor, just clean them off at every oil change.
-Thrust angle slightly off, still within spec. Despite 2 alignments. Just means it will torque steer slightly on take off. After installing the engine I broke a new mount on the drivers side. Have installed a limiting strap to keep this from happening again and of course replaced the broken mount.
-Rear sway bar removed for better articulation. This allows the rear springs to come out of the rear upper perches. I have a set of spring dislocation cones I will include with the sale.
Asking $6500 obo
Contact me through email and I will pass along my phone number.
bpeterson35@icloud.com
Goldenbora
