2000 E350 4x4 on 44" tires.
dansvan
Offroad tech bumper.
Warn m1500 winch with synthetic rope and aluminum fairlead.
Hella driving lamps.
Quick connect for jumper cables on bumper.
Custom aluminum flares.
D60 front with 5.13 gears and a tight Powerlok. Warn 35 spline hubs. Alloy shafts and stubs.
Front wheel bearing hubs modified with two grease fittings each.
Leaf spring front end from Pathfinder van.
V10 with unknown mileage. Van has 185k
No leaks. Runs better than any V10 I've ever driven.
Snorkle or cold air intake. Functional.
4r100 Trans.
bw1350 t-case
Custom front d-shaft with safety loop
Speedo electronicaly calibrated with Superlift speedo adjuster.
Scanguage installed to keep track of mileage, distance traveled, trouble codes, etc.
Additional power outlet on left side of lower dash.
Front rear heat and A/C. fully functional.
ABS brakes front and rear, fully functional.
Dual arirbags.
Factory CD/tape player AM/FM
Auto start with power door locks.
Power windows.
Custom made sliders.
Flowmaster 70 series muffler.
44" 16.5 TSL's
D60 rear with disc brakes and internal parking brake.
5.13's with detroit and alloy shafts.
Rear 18 gallon tank from ford pick up where spare tire used to be.
Rear tank has skid plate, does not hang below frame.
Rear dual mounted Optima batteries mounted behind rear axle on custom tray between frame rails.
Rear tire/hilift,gas can,shovel swing out mounted in rear to frame, through bumper.
Rear hitch flipped and installed through bumper. 7 pin trailer wiring.
Factory tinted windows.
Gray interior.
Black rubber floor mat over factory carpet.
3 (3) person bench seats.
Custom made rear bed with 4 drawers.
Cruise. tilt.
Custom steering box brace.
Steering stabilizer.
Removable rear mud flaps.
Block heater.
T-case clocked up for flat belly.
Runs excellent.
Drives very nice.Tires do flat spot. Once warmed up ride is fairly smooth.
You can converse at normal speaking volumes inside.
There may be more, but this is all I can think of right now.
Price lowered to 16,000$
Pics located here.
http://expeditionportal.com/forum/showthread.php?t=9453
email me at dansvan@mtaonline.net
Hijack on:
I'm fixing to do the exact same thing early this coming week. Do you have some pics or could you take some for me?
Sorry for the hi-jack. It is sure a sweet looking van. I read the write-up in the other thread to make sure you didn't already have pics of the batteries up over there.
Hijack off.
Here's a few pics after our trip to Moab and back. Kinda dirty.
Thanks! I want to enclose mine. I originally was going to hinge down the whole bracket, batteries and all. WAY TOO MUCH FABBING! After seeing your simple use of angle iron, it gave me an idea.... It would be much easier to make a bracket like yours, with sides and a bottom and have only one side hinge down for inspection/maintenance. That's the ticket.
Again, sorry to distract your sale thread, but you were a big help!
Best wishes selling your rig. Are you planning another rig? Looking at the pics you posted in the other thread, it sure looks like you use it quite a bit.
Wow,.....that thing is huge!
Good looking rig!
Good luck with the sell!
:26_7_2:
Welcome to the ExPo!
LukeSkywalker515
