Magnum Johnson
Selling my truck because im trying to buy a house and need to pay down on another loan or I would just hold onto it. I am a diesel mechanic and I have owned it since 2014. Its been sitting for almost a year now and I can't justify keeping it. I did drive it down to San Diego to tow another truck back up to Reno in August and she did great.
$18k OBO
177k Miles
2001 Dodge Ram 2500 short bed quad cab
24v Cummins ISB HO (only on 01-02 6spd trucks)
6spd NV5600 trans
4x4 LSD Dana 80 rear 60 front w/ 3.54 gears 1650 rpms @65mph
On board air (200psi)
500+ miles out of a tank
ZERO rust, So cal/Vegas truck
Engine:
Stock 24v Cummins
4" MBRP exhaust w/ muffler
Power puck (+2 mpg and 50hp)
Donaldson B105006 air filter
Newer drive belt
No excessive blowby
Newer VP44 injection pump w/ approx 40k
Always run with TCW-3 two stroke oil in fuel to preserve injection pump
Head gasket was resealed in 2020 to deal with an external coolant leak
Shell T6 oil run
Suspension/driveline:
Rebuilt HD steering in 2017 (no "Y" type steering)
35" Toyo AT's 50% tread on black Procomp 16x8 wheels
+3" front springs and Bilstein 5100's
Rear air bags
Previous owner replaced the rear spring with 3500 springs for towing
All fluids, diffs, trans, and transfer case replaced <10k miles ago
F/R brakes ok
Clutch replaced by previous owner and has approx 50k miles on it
Camper:
1984 Fourwheel Camper FWC Fleet, overhauled in 2014 with:
New Vinyl on popup +4" higher over stock
New liftpanels
MPPT charge control w/ 100w flexible panel
New water pump
10 gallon fresh water tank
LED lighting (switch in cab and in camper)
Blue sea fuse panel w/ new wiring
Custom switch panel w/ USB's and 12v outlet
Rebuilt door and lock
Resealed roof
Comes with 4x Rieco Titan Jacks
Custom platform to lift camper in bed to clear cab
Sleeps my wife and I plus my 11ys old and 50lb dog comfortably
Work Needed:
Truck spend 13 years in Vegas then in San Diego, the heat and sun took its toll...
Truck is losing clear coat (had planned to bed line truck)
Dash is garbage, it has a plastic cover and looks OEM
Dash bezel was replaced with Ebay china garbage, still garbage
Steering wheel is sun damaged on the top side and Cruise cntrl button is loose
Camper interior is dated and mostly stripped (works perfectly for our style of camping)
Camper plywood floor should be replaced (one soft spot and the rest is just 35yr old wood)
Parking brake shoes worn, have new shoes but I can't replace them due to a recent surgery
Just found out that there is an AC leak, obviously not working but compressor has less than 50k on it
Minor rear main seal leak, never have to top off just drips here and there and wanted to disclose
Truck and camper will not be separated.
I couldn't upload all of the pictures (files too large) so please reach out to me if you would like to see something specific.
$18k OBO
177k Miles
6spd NV5600 trans
Engine:
Stock 24v Cummins
Newer drive belt
No excessive blowby
Shell T6 oil run
Rear air bags
F/R brakes ok
Camper:
New liftpanels
New water pump
Resealed roof
Work Needed:
