2001 F350 7.3 Powerstroke 4x4 $16,000
IdaSHO
IDACAMPER
Time to sell Dads truck, a true 1-ton single rear wheel 7.3 Powerstroke
Looking for 16k, but will entertain all reasonable offers.
This truck is in great shape and with tons of recent work is ready for work/play/tow duties.
Same owner the last 10 years doing what these trucks do best…. hauling a fifth wheel camp trailer up and down the PNW. Has some miles, but has never been abused and is in great shape. Just take a look at the interior. Truck has had a bunch of recent work done, nearly $10,000 worth. Keep reading, if you are shopping 7.3’s, these are all things you will likely need when purchasing one of these iconic trucks.
All this work is done, done by the dealer, and I have receipts. Engine has zero, and I mean ZERO blow-by. Its easily the best running stock 7.3 I've driven.
Mileage as it sits is 285k Its runs great and auto trans shifts as it should, 4wheel drive with manual hubs works great.
Work done in the past couple hundred miles:
All 8 injectors
Both valve covers and under cover harnesses
High Pressure Oil Pump
Fuel Pressure Regulator
ICP
Starter
New serp belt and tensioner
Also done, by Moscow Auto, Rear driveshaft ujoints and center support bearing
Truck has also had a fresh radiator and water pump in the past 20k miles. I also just serviced the front locking hubs.
Complete with B&M turnover ball goose neck, good Nokian tires (65%), tow controller.
Its a high mileage Ford, so its not without its little issues.
Truck is located right in Moscow Idaho. Any questions, let me know.
Link to photo album.... https://www.flickr.com/photos/189864303@N07/albums/72177720327863591/
