2004 Ford E350 6.0 diesel campervan
Raniac
Selling my custom home-built campervan. Available locally in Denver on Craigslist. I haven't figured out how to get pictures into this ad, so please email me or see Craigslist ad.
This is a 2wd 6.0L diesel 2004 Ford Econoline E350 super duty EB(extended body) van. 160k miles.
I started with a few engine upgrades right when I bought it (Feb2015):
-Blue spring fuel pressure regulator
-upgraded turbo oil lines
-SCT Livewire tuner with touchscreen display($600 value) lots of power!
-EGT probe
-new 16psi radiator cap
-degas bottle pressure gauge plumbed into cab
-performed coolant flush with iron remover and upgraded to Xerex extended life coolant
-all fluids and filters changed regularly
-Rotella T6 5W-40 full synthetic oil
-running Archoil additive in oil and fuel system-great for injector life
Interior:
-FatMat sound deadening throughout
-plastic vapor barrier on walls
-Denim and reflectix insulation
-5mm wall panels wrapped in speaker fabric, secured to 2x4's along walls and roof
-Fantastic Fan roof vent- 3speed, bi-directional
-comfortable futon that slides out and folds down to a bed
-propane stove and sink on side doors for inside/outside operation.
-hardwood countertops with bartop epoxy
-110v 1.6 cu. ft. refrigerator
-dimmable LED lighting throughout
-diesel-fueled 7,000BTU interior heater with thermostat
-indoor/outdoor thermometer
-carbon monoxide detectors
-fire extinguisher
-Stereo:
-Planet Audio Anarchy 1800 amp
-10" sub with custom built box
-2 JVC 6x8's in the rear doors in addition to front stock speakers
-7inch double din deck
-Electronics-Everything in camper is powered on solar/batteries:
-(2) 100w Renogy solar panels hard mounted on roof rack
-Wanderer charge controller
-(2) 225AH 6v fully sealed AGM deep cycle batteries(wired in series to get 12v)
-ignition-activated battery isolator relay that links truck batteries to deep cycle (when ignition is on) for extra charging
-blue sea systems 12 blade fuse panel
-1000w Xantrax pure sine inverter(with 1.6farad capacitor in-line for power surging assist)
-(2) hard-wired 110v outlets in cabin
-Go Power 30amp automatic transfer switch for optional shore power(not fully wired for shore)
-LCD realtime load display (amps, watts, volts, power)
Exterior:
-custom steel roofrack/rooftop deck
-ARB4401A 8ft awning
-52" LED light bar
-18gal water tank, 3gpm pump, strainer, pressure tank, garden hose faucet
-basic external shower
-misters
-ARB twin compressor model #CKMTA12
-2.5gal air tank + accessories(hose, gauge, chucks, quick tire deflate tool)
-newer tires(30k mi on them)- Adventuro AT3 LT265/75/R16
-tire repair kit
-16" 8x165.1mm Helo HE791 wheels
-full size spare
-Aluminess rear bumper with deluxe box/rails, spare tire holder-built to also accept up to a 35" tire if desired once lifted. Onboard air output.
-UJOR front bumper(aluminum) with onboard air output. With two 7" round LED lights.
-billet engine grill
-bug/rock deflector
$35k
Feel free to email me with questions, to setup a time to check it out, or to send more specific pictures of anything. I also made a video that I can send you showing functions
iStan814
