2004 MITSUBISHI FG FOR SALE
Marcstrickland
2004 MITSUBISHI FG 4X4:
76375 MILES (SINGLE OWNER)
MODEL 639
3.9L TURBO 4D34T DIESEL
MITSUBISHI M035S5 5-SPEED MANUAL TRANSMISSION
3” EXHAUST W/ EXHAUST BRAKE
TOP SPEED 75 MPH (CRUISES NICE @ 68 MPH)
PARABOLIC SPRINGS (FROM ALL TERRAIN WARRIORS, AUSTRALIA)
17” SUPER SINGLE STEEL WHEELS (FROM AUSTRALIAN ADVENTURE VEHICLES) INCLUDING (1) SPARE
CAB THERMAL INSULATION AND SOUND DAMPENING MAT
VERY WELL MAINTAINED RE: OIL, FUEL, TRANSMISSION, TRANSFER CASE & DIFFERENTIAL MAINTENANCE.
70 GALLON ALUMINUM FUEL TANK
AVERAGES 10.5 MPG
ADDED FRONT FENDER FLARES
CUSTOM REAR WHEEL FENDERS
FULL SERVICE MANUAL PROVIDED IN PDF
JENSEN VX7022 STEREO HEAD UNIT W/ CD PLAYER, BLUETOOTH, INTEGRATED REAR BACKUP CAMERA
KENWOOD AMPLIFIER, 10” KICKER SUBWOOFER, 6X9 PIONEER SPEAKERS & PIONEER 3.5” DOOR SPEAKERS
CUSTOM STAINLESS FRONT BUMPER
WARN 15000# FRONT WINCH
GROTE LED FRONT LIGHT BAR
HEATED MIRRORS
LED BACK UP LIGHTS
TOWING HITCH
BFG ALL TERRAIN TIRES 37X12.5 R17 50% TREAD REMAINING
GROUND CLEARANCE 16" FROM TRANSFER CASE, 17" FROM FUEL TANK AND WASTE TANK BOX
EXTREMELY RELIABLE
HABITAT BOX:
CRAWL THROUGH PASSAGE BETWEEN BOX AND CAB
14’ LONG X 7’ WIDE MORGAN ALUMINUM PANELED DRY VAN BOX
2” CLOSED CELL SPRAY FOAM INSULATION
IPE HARDWOOD FLOORING
BALTIC BIRCH PANELING AND PLYWOOD INTERIOR
PASS THROUGH TO CAB
LED LIGHTING
LEATHER DINETTE CUSHIONS, CUSTOM RECLINING DINETTE SEATING
KITCHEN:
ISOTHERM 160 2 DRAWER REFRIGERATOR
2 BURNER MARINE ALCOHOL STOVE
PANASONIC MICROWAVE OVEN
CORIAN COUNTER TOP
CUSTOM SKYLIGHT
ELECTRICAL:
(3) PANASONIC 140W SOLAR PANELS
3000W GO POWER SINE WAVE INVERTER
(2) 210 AMP HR. AGM BATTERIES
SCHNEIDER ELECTRIC 12V CHARGER CONTROL SYSTEM
BLUE SEA SYSTEMS 12V & 120V DISTRIBUTION SWITCHES
TANK LEVEL MONITORING SYSTEM
HEATMISER TIMER CONTROLLER FOR HEATING SYSTEM
HOUSE BATTERIES ALSO CHARGE FROM TRUCK ALTERNATOR
BATHROOM:
THETFORD PERMANENT TOILET
SHOWER WAND WITH REMOVABLE HEAD
FANTASTIC FAN VENT 3-SPEED WITH CUSTOM VARIABLE SPEED DIAL & MANUAL OPENING DOME
PLUMBING:
50 GAL. FRESH WATER TANK
16 GAL. BLACK WATER TANK
16 GAL GREY WATER TANK
VALTERRA DOUBLE DUMP VALVE
SIGMAR ELEC. WATER HEATER
WEBASTO THERMO TOP C COOLANT HEATER (TO PREHEAT ENGINE AND HOT WATER SYSTEM. HOT COOLANT PROVIDES HEAT TO HEAT EXCHANGER/BLOWER UNIT FOR HOT AIR IN HABITAT.
CARBON WATER FILTRATION
THERMOSTATIC HOT WATER MIXING VALVE
BUNK & GARAGE:
FULL SIZE MEMORY FOAM BED
GARAGE/STORAGE AREA IS UNDER THE BED WITH LARGE DOOR ACCESS FROM PASSENGER SIDE EXTERIOR AND DOOR ACCESS INSIDE HABITAT.
MISC:
COLEMAN MACH 8 CUB LOW PROFILE A/C & HEATING UNIT (FOR USE WHEN PLUGGED INTO SHORE POWER)
AIR COMPRESSOR FOR TIRE INFLATION
12V PORTABLE FREEZER CAN BE INCLUDED (FITS IN THE GARAGE)
LOCATED IN PRESCOTT, ARIZONA $125K
ONLY KNOWN ISSUE: PAST MINOR WATER INTRUSION IN CORNER OF THE HABITAT BOX. RESULT: (DISCOLORED PANELING) -> IN 2023 I SPENT 1 1/2 MONTHS IN ALASKA WHERE IS RAINED NEARLY EVERY DAY. THE BOX HAS SINCE BEEN NEWLY CAULKED USING SIKA 221. MECHANICALLY THERE IS NOTHING WRONG EXCEPT THAT THE ABS LIGHT IS ON. ALSO, I NEVER CONNECTED THE TANK LEVEL SENSORS OR THE SEAT HEATERS. THIS IS A GREAT RELIABLE CAMPER AND HAS BEEN STORED INDOORS MOST OF ITS LIFE.
5mouse
