2005 GX470 Well Built
Fried
2005 Lexus GX470 Built-
151,000 miles, no kdss or nav, timing belt done at 90k, do dash issues, ash blue. Vehicle now runs and drives perfect. When I first purchased I was not happy with front end so I replaced EVERYTHING. I just replaced the gears (stock) after shearing a pinion on a trail. I built this vehicle for long term. Dream was the family would all wheel together. Well, life threw me a curve ball and I need to sell. For sale $14K OBO. Plenty of pics upon request. Located in Central Missouri.
• Initial baseline with new plugs, diff fluid, transfer fluid, filters, MAF sensor cleaned, etc…
• Delete running boards
• Airbag delete and installed Ironman foam cell shocks/coilovers (41mm) front from Metal Tech
• Light racing UCAs
• Ironman foam cell in rear
• Brand new Cooper ST Maxx 285/70/17 (less than 2,000 miles)
• New CV axles in front
• New moog ball joints front
• New tie rod ends
• New blue pit wheel bearings on front
• New rotors, calipers and brakes all the way around
• New gears after breaking pinion on the trail
• Bolt on trailer hitch from FJ to help departure angle
• Metal Tech OPOR sliders, bolted and welded
• RCI steel skid plates front/bash and lower control arms
• Needs SAIS bypass ($150) to fix sensor error
scande0
Also interested in pictures, what part of MO? I'm just across Mississippi in KY and have become infected with the GX bug. Is the SAIS causing limp mode?
iStan814
