2005 Jeep Wrangler LJ / TJ w/ Storage, Fridge, Kitchen, 50L Water | 97K Miles, $20K
ForestFaraway
For sale is my 2005 Jeep Wrangler TJ Unlimited “LJ” with 97,000 miles and many upgrades, including an integrated overlanders kit in the cargo compartment.
I’ve had this jeep for a number of years and I’ve taken it with me on many adventures all across the American West; but now it’s time for me to take up a new chapter and find a new home for this cherished project.
I listened to the various forum gods who guided me on a path to get an LJ to run 35's "correctly" - and it feels like it! The camper box in the back was made by me, and while I was originally going to carpet it over, I ended up liking the exposed birchwood.
The cargo box folds out to accommodate interior sleeping, holds 50L of water, holds 2x NATO 20L fuel canisters, an ICECO fridge, and two large kitchen drawers with a pop-out cutting board lid. It also has a section dedicated for mounting a standalone power station and can carry many dufflebags of additional cargo.
It is mounted to the OEM seat rail mounts, with an additional two large bolts to the deck itself. I've done trails in various parks and it has never given me an issue.
The engine idles quietly, revs quickly, and automatic transmission shifts perfectly.
All electronics are functional. The Jeep lived in California previously, in a heated garage, and has zero rust.
Happy to answer any questions! $20,000 OBO, located in Seattle, Washington.
Clean Title, Washington tags, ready to go.
Parts list:
  • Going and Stopping
    • 4.0L Inline Six
    • 4-Speed Automatic Transmission
    • Overhauled brake system, including new:
      • Calipers, rotors, pads, lines
      • Brake booster, master cylinder, and reservoir
    • Overhauled cooling system, including new:
      • Water pump, hoses, OEM Mopar radiator, fan clutch, belt
    • Other new engine components, including:
      • AIRAID CA-compliant cold air intake w/ box
      • Valve cover gasket, oil fill cap, PCV, etc.
      • New AGM battery
      • 2x CA-compliant Magnaflow catalytic converters and Bosch O2 sensors
      • Magnaflow resonator and muffler
    • OEM limited slip rear differential
  • Bending and Turning
    • 5.25” lift to fit 35” tires.
      • 4” Currie Suspension lift kit (CE-9131RH3P+CE-9132FP)
      • 1.25” Currie Body lift kit (CE-9122F+CE-9122R)
      • 1.25” Motor Mount lift
      • Currie Poly Bumpstop kits (F+R)
    • Suspension overhaul
      • 8x new adjustable, greasable control arms from rock-jock
      • Antirock front frame-mount sway bar (CE-9900)
      • All new steering components, OEM jeep Grand Cherokee upgrade
      • 4x new Rancho X9000 shocks + new 1x steering stabilizer
    • New wheels and tires
      • Set of 4+1 new 35x12.5R17 Nitto Ridge Grapplers, mounted to:
      • Set of 4+1 steel 17” wheels
  • Overland & Camping kit
    • I designed, built, and installed an overlanders kit to offer the following amenities included with the sale of the jeep, made entirely from Baltic birchwood.
      • Note that the original rear bench, carpets, brackets, seatbelts, and mounting hardware will be included with sale as well if you would like to go back to stock in the future.
    • Features of the Overland Kit:
      • Pull-out ICECO JP40 refrigerator, included w/ matching locking slide tray
      • Double-Folding cover that extends to a single full-size sleeping platform
      • 13 Gallon Freshwater Tank, w/ hoses
      • Storage compartment for 2x NATO 5g/20L fuel cans
      • 2x pull-out drawers on ball-bearing drawer slides
        • The lower drawer includes a kitchen top that opens w/ hinges
      • Storage compartment for standalone electrical unit (I used a Jackery, not included)
      • 2x rollcage mounted storage bags shaped for the rear corners
    • Other Interior Items:
      • 2x fitted Weathertech floormats
  • Exterior Bits
    • Steel front bumper with fog lights and winch
    • Steel rear bumper with swing out 35” matching spare
    • Steel Roof Rack, w/ mounted farm jack
    • OEM Jeep Hardtop
    • Doorless mirrors included
    • Raincover included
  • Other Things That I Have For The Jeep That I Haven’t Installed That Will Come With It:
    • UCF 1/4" 6061-T6 Aluminum Plate Deepcover Skid Plate for T-Case, Trans, and Engine protection that is also a “Tummy-Tuck” to gain additional ground clearance
    • Tom Woods NP231 Slip Yoke Eliminator - new in box
    • Novak NP231 Cable Shifter for T-Case - new in box
sebsync
