2006 Toyota Tundra DBL Cab TRD Off Road 4x4 $8900
real green
Time to let the hunt/fishing truck go. The bed is set up for sleeping. Bilstein adjustable 6112’s upfront. 2 inch blocks in back with Super Sumo bump stops. Front LBJ replaced with factory parts. Timing belt recently done. TRD Offroad package. 3000 watt inverter installed. Passed smog and tags are good through Sept 2026. Cheers,
It’s my daily driver and runs well, but here are the things I’m aware of:
  • Minor leak from the steering rack
  • Minor oil pan leak
  • ABS brake sensor needs replacing
  • Occasionally throws P0172/P0175 “rich” codes
  • Left front lower control arm is worn and affects alignment
M meadow build
