2007 FG Transmission and Tranfer Case Lube
EAB
Hi All,
What are folks using for Lube in their Transmissions and Transfer cases? I discovered that my transmission gear oil is migrating into my transfer Case. The cause may be a faulty seal but I replaced the output ******** final bearing/seal last year so not sure what is going on.
In the meantime I need to top off my transmission. The manual calls for straight GL-3 80 or 90 weight.
It also mentions for "long period of high-speed driving" use 30 or 40 wt. has anyone ever tried that?
The only thing I can find locally here in Bend is 80w-90.
What have folks been using?
Eric
pugslyyy
I've just used 80-90 weight. It's just a gear box, nothing that complicated going on...
More important to drain out the gunk and fill it to the right level, imho.
DFWSFO
