2009 Custom Silver Eagle Expedition Trailer M1101- Southern California
TLR4WD
A unique opportunity to purchase a turn-key M1101 Expedition trailer! This purpose built M1101 Expedition trailer is in Southern California and has provided “a go anywhere and fully off-grid” base camp solution for our family of four. The M1101 platform provides high ground clearance, can be easily towed by most vehicles, and has been further improved by adding many custom features including electric brakes and a fully articulating Lock and Roll hitch. The trailer is registered in CA, pink slip is in hand, and trailer is always garaged when not in use. A detailed list of features and pictures is included below. The trailer is priced at $13,000 cash or best offer. Serious buyers only, local pickup only, and can be viewed by appointment.
  • 2009 M1101 Silver Eagle trailer with rear stabilizers, standard 7-pin trailer plug, new shock absorbers, double wheeled tongue jack, and all LED lights (tail and running).
  • Dexter electric drum brakes including break away system, professionally installed.
  • Lock and Roll (full articulation for off-road) with adjustable height hitch system for any tow vehicle, professionally installed.
  • Low milage tires General Grabber X3, 37” x 12.5” x R17 (plus a full-sized spare, unused), three Moto Metal wheels (17 x 9”), and all hub bearings replaced (hubs and bearings meticulously maintained and serviced in last 300 miles of use).
  • Trailer Valet 5X tongue jack, drill adapter, and mounting bracket on trailer tongue.
  • Lockable jerry can mount on tongue and a lockable DMOS Delta shovel mount. Note the DMOS Delta Shovel (349.00 retail) and Lifesaver jerry can 18.5L (289.00 retail) are not included in price but can be optionally included for additional cost*.
  • KB Voodoo Max Modular Alumax 10” high aluminum bed rack SQ2249604, additional Bed Rack Top Bars for ALU Max racks SQ8162852, and many mounting points.
  • Lockable “junk” drawer above Dometic Fridge at rear of trailer.
  • Custom heavy duty aluminum pull-out slide (fabricated by Trail Kitchens) with L-track tie down system and one Old Milwaukee Packout mount (slide is 60 x 27 inch with a 500lb capacity). Old Milwaukee pack-out boxes pictured are not included in price, but can be added for additional cost*.
  • At front of trailer, there are two Better Built (67210276) lockable and weatherproof aluminum storage boxes.
  • Two Rotopak storage containers with mounting hardware (First aid container in orange color and Storage container in Black color).
  • 2 Yakima Open Range Tables (wood side table with sink and metal side table), covers, and quick deploy mounts on back and driver side of trailer (tables positioned under 270 awning).
  • LiTime 12V 230Ah Plus Low Temp Protection LiFePo4 Battery with Built-in 200A BMS, Max 2944 Energy with battery box enclosure.
  • Victron Energy BMV-712 Smart Battery Monitor with Shunt, Victron Energy Smart Solar MPPT Solar Charge Controller (Bluetooth)- 100V, 30 amp, 12/24 volt, breakers, battery master isolation switch, and fuse block (housed in weatherproof box at front of trailer).
  • Dometic CFX75DZW 12V refrigerator with Bluetooth and metal pull-out slide.
  • Mounted Renogy solar panel 100-watt 12V, high efficiency monocrystalline PV modular power charger RNG-100D-SS on a custom slide
  • Goal Zero 100W solar panel briefcase (monocrystalline solar panel, Boulder 100BC)
  • Portable Goal Zero Yeti 400 portable power station, 400Wh battery with 12V, AC, and USB plugs
  • LED lights under bed rack, on all four sides of trailer, and rechargeable led lights in all boxes
  • Mounted EcoTemp L5 tankless propane water heater w/ enclosure, 12V pump, strainer, 10ft hose and nozzle, and plumbed to two removable Reliance Aqua Trainer 7 Gallon containers.
  • Maxtrak mounting pins on tailgate (can hold 4 boards, Maxtrak boards are not included*), flag mount on tongue, axe and shovel Quick Fist mounts on passenger side of bedrack, fire extinguisher, and all stainless-steel hardware.
  • Tepui Ruggedized Autana 4 rooftop tent with Annex, interior LED USB light, shoe bags, ladder, interior table, and a 1.5” mattress topper. Olive color tent in excellent condition. Tent provides a king size bed (+2 people) and with lower annex can easily sleep two more people.
  • Driver side awning mount and OVS LTE 270 Awning with 1 side wall (all brand new!)
BUMP- A unique opportunity to purchase a turn-key M1101 Expedition trailer for your Spring adventures!
5mouse
