2012 Chaser $9500.00
lalineman
Located S/W Missouri
Chaser Trailer Kit Chassis, Trailing Arm Suspension with air struts, Cargo Box with gas strut assisted lid, Drop Leg Jack, Rubber Matting, Cargo Tie Downs, 2' Rear Accessory Receiver. Standard Powder Coat Color: White with Black Chassis & Fenders
Seel Powder Coated Nose Box 19" Tall x 16" x 30/14.5"
Two Fuel Cans & AT Holders for Trailer
19 Gallon roto-mold water tank with 1.25' opening, 1/2' drain plug and pump
Partner Steel 2 Burner Stove with lid and wind screens
Utility shelf for Chaser (16.5' x 43' x .75'), shaped and finished hardwood ply with locator pins.
Auxiliary 12V Power wiring w/ night light, ARB Adventure LED light, 3 fused outlets, battery tray and hold down
Valve Regulated AGM group 31 deep cycle battery 105 Amp
Noco Marine Charge On board 10 Amp single battery charger & maintainer with Shore Plug Installed
Electric Braked Axle Upgrade with 10"' drums, includes break-away kit
Globedrifter Trailer tent. Beige 4 sidewalls with windows, bug mesh, door. Integrated, self-supporting retractable awning. Separate floor. Bed size 79' x 63' with 3.3' thick mattress.
Fitting and adjusting: ladder & cover, inspection of tent and hardware. Mounting tent to roof bars using AT hardware.
3 Load Bars on Adjustable Track
Chaser Tail gate 16' x 32' with locking T-handle latches.
Multi Axis Coupler, 6000 lb, Class III.
National Luna Weekender, 50L Fridge/ Freezer, Split, Stainless Steel: Weight: 58.5 lbs (26.5 kg). Materials: Rigidized stainless steel exterior, smooth stainless steel interior.
Fridge base plate for 50/52 Weekender National Luna Fridge.
50/52l National Luna Fridge Protection Jacket
6 LED Rectangular HD Flood Light 4'x6' (12/24VDC)
60 W foldable panel, RV-20 controller, 15ft extension cord, weatherpac kit, RV plug male and female, installed in AT nose box.
Aero Silent Hitch Pin
Propane Bracket COMP. Fits 9" diameter, 10 lb Propane bottle. Supplied with 2 clamps
Manchester 10 Manchester 10 lb vertical propane cylinder.
Deluxe stainless steel sink designed to fit both Chaser & Horizon model trailers. Complete with mounting instructions and all mounting hardware.
Rear Stabilizer
BFG Mud Terrain KM2 37x12.50R-17LT, Overall Diameter = 36.8, Load Range = D, Max Load = 3525lbs
Inverter 1500 watts
Fuse, MEGA Bolt On Fuse; 300 Amp
Fuse Holder, MEGA Fuseholder; Fuse Block
Propane 12ft hose
Wedco Water Can-Metal
Wedco Spout for Metal Water Can
“New equipment”
A second propane tank & holder same as original specs
New mattress custom made.
Tire swing gate
New airbags
Aluminum table & rack
New black tent cover
Sent from my iPhone using Tapatalkk
5mouse
