Good stuff Lance. I may have to take a look at this....G`day All
I had a good look at converting my FG to disk, very doable.
We have oodel`s ( technical term for heaps of them) brand new take off disk/caliper for the FUSO FE . Axles front and rear Disk to disk it was pretty easy to mock some simple stuff up. Both front and rear of the FE are dual caliper, they really stop.
A new hub would be needed to accept the FG spindle or Machine the FE Hub to accept the FG bearing and FWH assembly , I think there is enough meat there. Through boring of the hub might get tricky to get both bearing surfaces perfect, lots of smarter people than me know how to do that sort of thing.- 17 inch wheels would also be a must. The brake master is a off the shelf part nothing exciting there. FE uses heavier rear axle , it would easier to just change the entire assembly for four wheel disk is desired. I am not sure i will ever get the time to do it.View attachment 699413
Lance
Changing the axles for some shaking brakes is like throwing the baby out with the bath water. The stock FG axles are extremely robust. If you do have worn ball joints or steering components they are cheap so get them replaced. Otherwise just have the drums turned. The brakes on these trucks last just about forever and get the job done well enough. Particularly if you use the exhaust brake.Thank you for the replies guys. I'm definitely looking for off-the-shelf parts to keep replaceability good. I was hoping I would be able to grab a different model fuso setup for the rear and things might go together with minimal issues. Designing wheels around the swap is fine.
The fronts I understand would be more of a b***h because this is the only use of the solid front axle that Mitsubishi has on a rig.
I was hoping someone might have gotten under their rig with a caliper and measuring tape to determine if any other model vehicles have a matched size setup. As far as knuckles and axles go, I figured we might strike a win with something more readily available for another type of HD truck
Sounds like nobodies having any luck. Why you gotta be like that Mitsubishi? Smh??
I'll contact earthcruiser this week and perhaps they'll be able to divulge some of their past headaches that lead to their current setups.
I'm really bummed about this literal bump in the road. I have been experiencing braking issues with my fuso since I picked it up and while they seem to be somewhat normal for the vehicle, violent shaking while coming to a stop from a truck with only mildly worn ball joints or steering components signals an engineering flaw I'm not entirely sure I want to invest in solving. If the answer is swapping the axles out for something different I may end up abandoning this build and selecting a different chassis. Ive experienced every downfall of drum brakes imaginable and I'm not willing to build something on them.
I will update my findings as I find them. Smh
