2014 E350 Caster
Jsweezy
I have a 2014 E350 2wd that I would like to tighten up the steering on and have read that using something like an Ingalls 594 can achieve that by adjusting the caster. Most of what I have found involves doing this to older model E350s though so I was wondering...
Has anyone done this to their van and if so what did you use and were you able to make the adjustment yourself?
Thanks!
FordGuy1
Super easy to install a slug. You can do it without having it on a alignment rack, but I would install them and then take to a shop and dial it in. It is nice to have a base line before you start, I would not go below 2deg or the steering starts to get pretty crappy and starts to not return well to center.
Jsweezy
Ok, Thats what I figured as far as the installation but just wasn't sure what exactly to go to and was hoping someone else had done it and figured out the sweet spot. Thanks for the confirmation!
philos
I put the Ingalls 594 bushing in my E350 after I put new springs, etc. Then I took them back out in favor of a fixed angle for my caster settings. They didn't help at all in my case, if anything it was worse...
crostopher
