rparker017
Selling my 2014 FJ Cruiser. This is a Trail Teams Ultimate Edition that came from the factory with a rear locker in addition to the unique paint color, wheels, and blacked out trim. This vehicle has just under 53,000 miles and the mods, parts, maintenance were all done less than 500 miles ago. With mods and new suspension, the truck sits 2" higher than stock in the front and 2.5" in the rear. Runs and drives great and is in excellent shape inside and out. I recently removed the skids and treated the frame, suspension components, and axle housings with Eastwood Rubberized Rust Encapsulator to take care of surface rust from a few PA winters. The only issue I'm aware of is slight tire rub on the body mount in certain circumstances - it could use a body mount chop (fairly common with Toyotas running larger than stock tires). This FJ is in need of a new owner to take it on camping trips and other outdoor adventures. I'm happy to answer any questions or take additional pictures.
Edit: Clean Carfax report and PA title in hand.
Make: Toyota
Model: FJ Cruiser (Trail Teams Ultimate Edition)
Engine: 4.0L V6
Transmission: 5-speed automatic
Miles: 53,000
Price: $35,000
Armor:
Front Bumper: Ex1 Kodiak (Steel)
Rear Bumper: Ex1 Trail Series (Steel) w/Swinging Tire Carrier, Backup Camera, Hi-Lift Mount
Rock Rails (OEM)
Full Aluminum Skids (OEM TRD, RCI ,Ricochet combo)
Shrockworks Rear Link Skids
Suspension:
Front: Radflo 2.5" Extended Travel Adjustable Coilovers & Total Chaos Uniball UCAs
Rear: Radflo 2.5" Extended Travel Shocks, 2" Lift Springs, Metaltech Lower Links
Tires:
(5) Wild Country XTX, LT285/75/R16, Load Rating: E (less than 250 miles)
Recovery:
Warn Zeon 10-S (synthetic rope)
Factor 55 Closed Link Hook
Shrockworks Winch Kill Switch
Crosby 3/4" Shackles
Hi-Lift Jack
Lights:
Front : PIAA LED LP530 Fogs
Rear: PIAA LED 3.5" Floods
Interior:
Rugged Ridge Floor & Cargo Mats
Console Vault
Springtail Molle Panels & Basket in Cargo Area w/Storage Pouches
Other Mods:
Tow Hitch Added - Toyota OEM Hitch & Wiring
Transmission Cooler Added - TruCool 4454
Breathers Extended to Engine Bay (Rear Diff, TC, Front Diff, Transmission)
ECGS Bushing Installed in Front Differential (Replaced Needle Bearing on Driver Side)
Rad Rubber Splash Guards
Ex1 Washer Bottle Relocate Kit
Warrior Diamond Plate Trim
Maintenance:
Fresh Motor Oil & Filter
Fresh Gear Oil in Both Differentials & Transfer Case
New Optima Yellow Top Battery
Make: Toyota
Engine: 4.0L V6
Miles: 53,000
Price: $35,000
Armor:
Rock Rails (OEM)
Suspension:
Tires:
Recovery:
Hi-Lift Jack
Lights:
Interior:
Console Vault
Other Mods:
Maintenance:
