2015 Jeep Wrangler JK Rubicon W/Ursa Minor/Goosegear camp kitchen - Loveland, CO
MSD
Well Known Xplor’r
$45k obo located in Loveland, CO
mileage 71k may vary slightly with minor drives.
As title of ad states 2015 Jeep Wrangler JK Rubicon W/Ursa Minor/Goosegear & camp kitchen stove. Its a Rubicon, so DANA 44 axles, front and rear lockers, sway bar disconnect etc…
As far as upgrades go, I have done lots to make it a capable overlanderer or even a rocklander if you want to wheel it harder. Upgrades listed below… well over $55k in upgrades not including labor.
This is a well sorted rig and can tackle whatever you want to throw at it.
Upgraded 2017+ mopar injectors (better than stock)
MSD Blaster coils and NGK premium spark plugs
WARN ZEON 10-S WINCH W/ SPYDURA SYTHETIC ROPE AND WARN EPIC 1.5 FAIRLEAD
-LOD DESTROYER FULL-WIDTH FRONT BUMPER W/ BULLBAR
-JW SPEAKER 8700 EVOLUTION 2 DUAL BURN HEADLAMPS
-JW SPEAKER 239 J2 SERIES 3.5 IN ROUND LED
-AEV SAVAGRE WHEELS BLACK 17X8.5 5X5
-BF GOODRICH ALL-TERRAIN T/A KO2 37X12.50 R17 LT TIRES W/WHEEL PROS TPMS SMART SENSOR ONE RUBBER VALUE SNAP-IN
-DYNATRAC PROGRIPBRAKE UPGRADE SYSTEM (new rotors & pads added 3k miles ago)
-NITRO 5.13 RING AND PINION
-AEV PROCAL MODULE
-K&N AIR FILTER
-GENESIS OFFROAD DUAL BATTERY KIT 200 AMP ISOLATOR W/ 2 OPTIMA YELLOW TOP BATTERIES
-sPOD BANTAM W/ 8 SWITCH PANEL SYSTEM BLUE
-RIGID INDUSTRIES E-SERIES PRO MIDNIGHT EDITION SPOT LIGHT 6 IN
-RIGID INDUSTRIES D-SERIES PRO MIDNIGHT SPOTLIGHTS
-LOD SIGNITURE SERIES SHORTY REAR BUBPER W/ GENERATION 4 TIRE CARRIER AND GENERATION 3 TRAIL RACK SYSTEM
-JW SPEAKER 279 J SERIES LED TAIL LIGHT KIT
-HI-LIFT 48 INCH X-TREAM JACK
TERAFLEX LIFT KIT W/FLEXARMS AND TRACK BAR 4.5 INCH LIFT
Terra flex bump stops front and rear
Terra flex premium ball joints
Clayton 4.5” heavy duty coil springs
LOD signature series front plate older
Mishimoto high flow all aluminum radiator
Mishimoto silicone hoses
Metal cloak rear diff cover
-TERAFLEX FALCON SERIES 2.1 MONOTUBE SHOCKS FRONT AND REAR
-MAGNIFLOW MF SERIES PERFORMANCE CAT-BLACK EXAUST SYSTEM
-Blacked out URSAMINOR J 30 POP UP CAMPER TOP WITH 2 GALLON WATER ROTOPAX ON RIGHT AND LEFT SIDES AND YAKIMA SKYLINE ADJUSTABLE RACK
-RHINO-RACK BATWING AWNING
-GOOSE GEAR 60% REAR SEAT DELETE W/ LOCKABLE STORAGE
-GOOSGEAR REAR PLATE W/ SUBWOOFER GRILLE
-GOOSE GEAR CAMP KITCHEN WITH ARB FRIDGE W/ GRILL AND REAR HATCH CUTTING BOARD.
I’m sure I’ve forgotten some things and will update add as I go thru my build sheet. This is a well taken care of and sorted rig.
TTT with some pictures
M meadow build
