2015 Jeep Wrangler Unlimited Rubicon Ultimate Crawler - Overland Vehicle
Vader
13,406 Original Miles
Arvada, Colorado
**Please read the entire add for details and pricing at bottom of page**
I special ordered this fully loaded Jeep Rubicon in 2015 for $46,952.00 with a goal of building my dream version of a serious Crawler/Overland vehicle, using top of the line parts. The price for the parts including tax came to around $33,000.00 and does not include any labor costs as I did a majority of the work myself. An estimate for the labor would have been somewhere between $15K - $30K. To build a Jeep similar to this you would easily pay over $100K. I never planned on selling this Jeep but due to a business opportunity and the fact that I haven’t been able to get out and use it as I had planned, I have made the decision to let it go to a new home where it will be used appropriately as it only has (13,406 original Miles) and is ready for some fun. This Jeep has been off-road twice and stored in my garage it’s whole life. It’s in newcondition and basically spotless with no dents, dings or even rock chips as you can see by the pictures. All leather seats and steering wheel have been covered since the original purchase by Trek Armor (Bartact) seat covers and never sat in except for the drive home from the dealership. This jeep comes with the hard top for winter and the Mopar premium “full” soft top for summer.
Listed below is a detailed breakdown of all the work done and pricing.
The Build:
The Jeep has a 3.6 Pentastar Engine with an automatic transmission runs flawless.
The new work consisted of adding a (modified) Rock Krawler 4.5” lift kit with Fox Racing 2.5 Adjustable shocks to accommodate 37”- 40” tires, upgraded chromoly axles, 513 Yukon gears, Dynatrac Pro-Grip Brake system, Poison Spyder diff covers, Alloy Super u-joints and ball-joints, Rockslide Engineering front & rear bumpers, electric steps/rock sliders, overlanding accessory carrier, Rock Hard 4x4 undercarriage skid plates, 14,000 lbs. Superwinch with Synthetic rope and Roam mobile controller, Odyssey Battery, luxury sound system, and high end alarm and remote start.
Included in the sale are several miscellaneous items listed below and some optional items for sale.
Detailed list of parts with pricing and taxes when purchased.
Lift KIT with upgraded parts:
  • 4.5” Rock Krawler XFacter Mid Arm Lift Kit. $3,307.70
  • Rock Krawler Triple rate coil springs
  • Rock Krawler Off-road Pro Drag Link.
  • Rock Krawler (2) Adjustable 1.5” solid alloy steel front track bars.
  • Rock Krawler (4) High clearance adjustable lower control arms.
  • Rock Krawler (2) High misalignment double adjustable front upper control arms.
  • Rock Krawler (2) High misalignment double adjustable rear upper control arms.
  • Rock Krawler (2) Adjustable front sway bar quick disconnects (greaseable).
  • Rock Krawler (2) Rear extended sway bar links (greaseable).
  • Rock Krawler Rear track bar relocation bracket
  • Rock Krawler (4) Long travel stainless steel brake lines.
  • Rock Krawler (1) Pair of rear sway bar straps
  • Rock Krawler (2) Rear coil spring degree wedges
  • **Rock Krawler aluminum Off-road Pro Tie Rod. $585.78
  • **Fox Racing 2.5Reservoir shocks w/DSC adjustable in front and rear. $2,500.00
  • **Fox Racing Steering stabilizer. $170.00 ,
  • **Synergy-Steering stabilizer-track bar relocation bracket on front. $61.91
  • **PSC Steering stabilizer clamp. $90.44
  • **JKS Adjustable Bump stops. $130.00
  • Mopar Front extended Double Cardin front drive shaft. $575.00
Axle-Diff-Brake upgrades:
  • Dynatrac Progrip Brake System. $1,168.36
  • Yukon 513 gears to accommodate the 37's (front & Rear). $1,199.00
  • Poison Spyder front & Rear Diff Covers. $236.70
  • Carbon Offroad (rear) Rubicon Dana 44 Rear Chromoly Axles. $585.78
  • Alloy 4340 Chromoly (Front) Axles. $860.00
  • Alloy Heavy Duty (Super) U-Joints. $142.00
  • Alloy Heavy Duty Ball Joints Upper & Lower. $203.76
Bumpers-Sliders-Skid Plates:
  • Rockslide Engineering Step Slider (electric step and rock slider). $2,026.23
  • Rockslide Engineering Front Bumper-stubby or full-size option. $1,600.00
  • Rockslide Engineering Rear Bumper with tire carrier up to 37" tire. $1,600.00
  • Rockslide Engineering Shovel and RotoPax Mount. $275.00
  • Rockslide Engineering Step Slider door delete kit, and light kit. $118.35
  • Rockslide Engineering Vacuum Pump Relocation Bracket. $21.00
  • Rock Hard 4X4 Oil Pan/Transmission Skid Plate. $451.86
  • Rock Hard 4X4 Transfer Case Skid Plate. $290.46
  • Rock Hard 4X4 Gas/Fuel Tank Skid Plate. $451.86
  • Rock Hard 4X4 Evaporator/Charcoal Canister Skid Plate. $123.68
  • Rock Hard 4X4 Rear Lower Control Arm Skid Plates. $86.02
  • Rock Hard 4X4 Front Lower Control Arm Skid Plates (Not Installed) $86.02
  • Rock Hard 4X4 Doublewall Transmission Crossmember (Not Installed). $268.94
Sound System $4,016.80:Kenwood DNX573S 6.2" with Garmin Navigation and Backup camera.
  • Focal 6" Flax Component Set.
  • Maestro Interface.
  • Addictive Audio 695.1 Amplifier.
  • Addictive Audio 100.4 Amplifier.
  • Addictive Audio 10" Version 2 Dual 2 OHM Subwoofer.
  • Custom ported subwoofer box. (Removable)
Alarm-Remote Start:
  • Compustar MAX IT Pro T12 Alarm and Remote Start. $825.00
Miscellaneous Parts:
  • Odyssey Battery. $246.99
  • Superwinch Talon Off-Road Winch-Synthetic Rope-Hawse Fairlead-14,000 lbs. $2,326.18
  • Superwinch Roam cordless WIFI mobile controller system. $350.00
  • AEV Controller (adjust computer for tire size etc). $229.99
  • Trek Armor (Bartact) seat covers. Fronts & back and padded console cover. $862.95
  • Carolina Metal Masters, JK Billet Front and rear Grab Handles (Brass Knuckle). $419.64
  • Synergy CB antenna mount. $14.96
  • Firestik antenna's (3' and 5'). $66.00
  • Quadratec Floor Liners (front-back-cargo area). $209.97
  • Quadratec locking gas door. $65.00
Included with Sale:
  • Bestop Hardtop Cart. $259.00
  • (5) Goodyear Wrangler MT/R’s with Kevlar Tires LT315/70R17 (almost 35’s). Spare is new, other 4 tires have approximately 4,000 miles of wear with two off-road trips. $1,709.95
  • (5) Method Racing NV wheels. $1,521.55
  • (4) Spidertrax 2" Wheel Spacers for Method Racing Wheels. $258.24
  • Mopar 410 gears for the 35” tires.
  • Spare front & Rear Dana 44 Rubicon Axles.
  • Spare tie-rod.
  • (Extra) rockslide Engineering Circuit board for Stepsliders.
  • (EXTRA) rockslide Engineering motors for both Stepsliders.
  • Rock Krawler quick disconnect Sway Bar Links (front & rear).
Additional Items for sale that we could discuss if you’re interested:
  • New Powertank and roll bar bracket. $800.00
  • Passport Max 360 Radar Detector with direct wire Kit (Jeep is currently wired for radar detector). $679.90
  • (5) Maxxis Trepador tires 37x13.50-17 (New and on Jeep). $2,659.75
  • (5) ATX Beadlock Slabs (true beadlocks new and on Jeep). $1,888.55
  • Dyna Beads for all 5 Maxxis tires. $162.33
Thanks so much for considering this highly modified Jeep JKU Rubicon, I have over $100K into this Jeep.
Asking $60,000.00 OBO, feel free to contact me with any questions.
Mike
ELShockley
