Lhenecke
Not many on the East Coast - Crux 1600 in great condition, with independent suspension and articulating hitch. Curb weighs is only 1,800 pounds. The Crux 1600 has an outside kitchen with a propane cook stove and sink. The unit also has an 18-gallon freshwater capacity. Rear compartment slide carries a SnoMaster 42L fridge. It is incredibly capable off-road and will go anywhere your tow vehicle can pull it. Tons of storage, with sliding drawers in locking compartments. This unit comes fully loaded with a huge awning/annex room that covers the kitchen. New Regony deep-cycle 100ah AGM battery.
- Trailer dimensions: L 11’6” x W 5’5” x H 4’9”, Tongue Weight: 220lbs Curb Weight: 1,800lbs, GVWR: 3,300lbs.
- Suspension: Independent suspension (all new bushings) with heavy duty springs and gas charged shocks 10” electric brakes with a hand brake on the draw bar, Dual drawbar safety chains.
- 360-degree Poly Block coupling with heavy duty swing up 10-inch Jockey wheel
- Chef’s Galley: Slide out stainless kitchen with two burner propane stove, 20lb propane tank with hose, sink and electric water pump.
- Electrical: 100A/H deep cycle battery, overload protection, two 110V outlets, two 12V outlets, 1000w inverter. Battery is charged by your vehicle when 7 pin style plug is connected, or solar power, battery pigtail connector for storage float charging, a 100-watt folding solar panel.
- Water Tank: Stainless Steel 18 gallons with alloy skid plate, external hand pump for quick washups
- Bed Size: L7’1” x W5’7” with ladder
- Tent: 15oz Coated Canvas tent and ones with an additional extra-large annex room. All canvas material is 150z double stitched, waterproof, mildew resistant canvas roof and sidewalls with heavy duty Velcro and zippers. Mosquito proof and UV protected window screens with polyethylene rubberized floor in vestibule and detachable polyethylene floor in annex.
- Chassis: Heavy duty, off-road, galvanized steel frame with stabilizers and mesh rock guard
- Rims and Tires: 15” alloy rims, six bolt pattern and 31” x 10.5” Cooper Tires, with matching spare. Standard 7-pin connection plug.
- Storage: All storage doors have air-tight, waterproof seals and locks Two jerry can holders on drawbar.
- Lights: LED lights throughout trailer, in crucial locations: chef’s galley, electrical panel, refrigeration chamber, LED tail and running lights
